Fuel pump question....
Old May 21, 2021 | 06:43 AM
maybelooking's Avatar
maybelooking
Default Fuel pump question....
thought I might get more responses in this section. https://www.corvetteforum.com/forums...-question.html
I know this topic has been beat to death. I have read until my brain hurts. Any help is much appreciated.
I would like to just be able to swap pumps and be done if that's possible. Im not shooting for mega horsepower here. 500-550 to the wheels is it. The 255lph pump isn't keeping up.
Thanks.
Old May 21, 2021 | 01:08 PM
grinder11's Avatar
grinder11
Thanks.
Maybe try a Kenne Bell boost-a-pump on the stock pump? It increases voltage to the fuel pump, but I believe it's only at WOT/open loop. Many people have used them with success. Best of luck to you.
Old May 21, 2021 | 03:19 PM
mmartinez's Avatar
mmartinez
The boost a pump is usually used in supercharged applications where a Hobbs switch turns on the boost a pump while under boost. If your horse power goal is normally aspirated you should install a higher capacity pump. The boost a pump raises the voltage to the fuel pump, you do not want it on all the time.
To Fuel pump question....
