1999 c5 ecm
Old May 23, 2021 | 09:40 PM
C5fourme's Avatar
C5fourme
Cruising
Default 1999 c5 ecm
Thanks for allowing me to join. Have my first Corvette at 68 years young. Is it true that there are no new ECM’s for the 97-01? Thanks
Old May 24, 2021 | 07:06 PM
mmartinez's Avatar
mmartinez
Not true, you can still find them, as well as several places that can rebuild them. ECM or PCM as we call them are very robust, the one thing you have to check for is a leaking battery, because the pcm is directly below it.
Old May 24, 2021 | 07:16 PM
C5fourme's Avatar
C5fourme
Cruising
Thanks for the update.
Old May 24, 2021 | 07:44 PM
feeder82's Avatar
feeder82
If you left out a letter the EBCMs are the culprits that are not available except used for a high price
Old May 24, 2021 | 08:51 PM
C5fourme's Avatar
C5fourme
Cruising
Those concerns the brake module. Anybody rebuilding them? If not and you cannot find one then what? Thanks
Old May 24, 2021 | 10:33 PM
feeder82's Avatar
feeder82
The older ones can't be repaired, there's a sticky thread where a 99 ebcm was converted to a 01 to 04 successfully. If you can't buy a used one, you drive without abs
Old May 25, 2021 | 07:08 AM
C5fourme's Avatar
C5fourme
Cruising
Thanks and I will try to find the thread.
Old May 25, 2021 | 08:12 AM
feeder82's Avatar
feeder82
https://www.corvetteforum.com/forums...m-success.html
To 1999 c5 ecm
