C5 climate control need help, I am stumped
Old May 24, 2021 | 09:05 PM
darrellw's Avatar
darrellw
6th Gear
Default C5 climate control need help, I am stumped
NEED HELP..I have a 97 coupe, climate control works every now and then. lights up good (not dim) when it does run, even purchased a remanufactured unit and it does the same thing, checked fuse #18, and it is good, unit buttons lights up when car lights are on,but screen stays blank, checked ground points and they are all clean. not to sure of what to check next, any help would be greatly appreciated
Old May 24, 2021 | 11:27 PM
SilverC54me's Avatar
SilverC54me
Your issue is some where upstream from the HVAC controller. One possible issue is the ignition switch. Contacts within it can arc over time leaving carbon deposits. I would either clean the switch or replace it.
Where are you located, there are many members that can assist with the troubleshooting of your issue.I would be willing to help if you are in Southern California.
Gary
Old May 25, 2021 | 06:42 AM
darrellw's Avatar
darrellw
6th Gear
Thank you Gary, I will try it, located is western Colorado
Old May 26, 2021 | 11:49 PM
Moved to C5 Tech.
To C5 climate control need help, I am stumped
