BCM Codes
Old May 24, 2021 | 09:58 PM
tkw's Avatar
tkw
Cruising
Default BCM Codes
Just checking if anyone knows what these BCM codes are
B0605H
B2723HC
Old May 25, 2021 | 12:03 AM
mmartinez's Avatar
mmartinez
The internet is your friend.
Old May 25, 2021 | 07:06 AM
Gordy M's Avatar
Gordy M
The B2723HC means you have problems with the chip in your ignition key, It is a past and present condition.
The B0605H means your BCM had a problem internally in the past.
Old Jun 21, 2021 | 07:52 PM
Crazy curves's Avatar
Crazy curves
You can look online to find out what the codes mean. I do know that H means history, that it was something from before and C means current.
Old Aug 6, 2021 | 11:48 PM
gr8diver's Avatar
gr8diver
I have a 03 Z06 that has been sitting for a month or so. I went out to move it today and it woudn't start. I charged the battery and got it started. I drove it around our community. As I was driving, it went into reduced power mode. When I got it back to the house, I shut it off and looked at the codes. I had probably 12 total codes (including the traction control). I tried to start it again....no joy.
I took the battery out and had it checked. It was bad...After replacing the battery, I cleared out a couple more codes and it runs fine now...no codes, no issues.
Batteries must be charged or else
Old Aug 7, 2021 | 08:31 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
VERY true!
People have been arguing for DECADES, as to what's the best battery for a C-5 Corvette. Given what I've seen and experienced, a "fairly new, fully charged" (no matter what brand) battery, is the "best" one........
Old Aug 7, 2021 | 10:46 AM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
The more I look at this I bet it is ignition switch. There is a voltage issue with the tcs and another low voltage. Anxious to see what happens with a new switch. It also looks like the previous owner used a tech 2 and blocked the f45 shocks
oops wrong thread
To BCM Codes
