rad leaking
Old May 28, 2021 | 05:48 PM
carhodge's Avatar
carhodge
Default rad leaking
think I have rad leak,need to take it our any tips ?
Old May 28, 2021 | 06:41 PM
Brewssard's Avatar
Brewssard
check out YouTube. Lot of videos.
Old May 28, 2021 | 07:03 PM
jcgunn's Avatar
jcgunn
Might also be time to replace the hoses, including the heater hoses.
Old May 28, 2021 | 07:31 PM
carhodge's Avatar
carhodge
yep
Old May 29, 2021 | 12:05 AM
jim993's Avatar
jim993
What makes you think the radiator is leaking?
Old May 29, 2021 | 12:17 AM
chilnviln's Avatar
chilnviln
from what I heard you remove the radiator by sliding it out from underneath the car, not from above. not sure if you could do it the standard way as I had the dealership change mine.
Old May 29, 2021 | 12:40 AM
jim993's Avatar
jim993
I removed mine from above. Protect fins on the new radiator and existing AC condenser with a sheet of cardboard-
Old May 29, 2021 | 12:46 AM
o2bnkc's Avatar
o2bnkc
The plastic tanks have a tendency to split and leak.
Old May 31, 2021 | 12:27 AM
Moved to C5 Tech.
Old Jun 3, 2021 | 08:11 AM
carhodge's Avatar
carhodge
my thoughts
Old Jun 3, 2021 | 10:51 AM
gopro_2027's Avatar
gopro_2027
my thoughts
I replaced mine last summer and it comes out the top. Mine had front end damage so maybe it was harder than it should have been but it was a royal paint to get all 4 of the groves lined up. It slots into 4 spots. And if you have the automatic (not sure which years, probably 01-04) then you need this obscure tool to disconnect the transmission fluid lines. It took me so much effort with other methods before I finally paid the $30 for this piece of plastic but it worked great.
Amazon Amazon
Old Jun 3, 2021 | 11:00 AM
grinder11's Avatar
grinder11
Out the top. I have a good used one I COULD sell you, but Id really rather not.. I think it's best to upgrade the radiator to an all aluminum one. If you don't, you'll just reinstall the problem if going OEM.....
Old Jun 3, 2021 | 01:32 PM
gopro_2027's Avatar
gopro_2027
What problem is that? Cracking? Overheating?
Old Jun 4, 2021 | 10:06 AM
grinder11's Avatar
grinder11
The plastic tanks are generally the problem. Theyre usually good for 100,000 miles+. On a NEW car, one that's driven 10,000-15,000 miles per year. C5s haven't been new for a LONG time. Parts have a shelf life. Yours went bad, but it wasn't the low miles you have, or lack of maintenance. It's an old plastic part at this point in time. A factory replacement, if available, has probably been sitting in a warehouse, or on a dealers shelf, for at least 10 years. How long do you think the "new" radiator will last? 20,000 miles, 50,000 miles? I'd upgrade to a DeWitts, or other quality radiator out there, and you're set from that point on. Plus if upgrades are in you're future, you won't need a bigger radiator. Hope this helps....
To rad leaking
