T56 wiring HELP!
It wasn't until I got the trans in the car enough to plug everything up that I noticed none of the plugs fit any of the sensors or switches in the trans.
ok. I'll order a c5 backup lamp switch (hopefully it can be changed with the trans in the car because they wont let me keep it apart on the lift at work).
BUT according to google the reverse lockout i the same part number so the plug should be that same...no?
Also it look like the sensor on the lower drivers ide is a trans temp sensor on the 05 trans, but I can seem to find a sensor for a c5.
