Coolant Change Guru's, Questions
Also, the "reving" from idle to 3000 rpm at 30 second intervals, is this a quick rev to 3000 and back to idle ever 30 seconds or increasing rpm from idle slowly to 3000 and slowly back to idle over a 30 second period?
If system holds 3.15 gallon (12.4 quarts) how much can you really get out with the drain?
Just want to do it correctly with no air in the system.
Thanks for any guidance.
In fact, I just refilled mine this weekend using the service manual procedure and it worked perfectly. :cheers:
[Modified by Patches, 10:11 AM 12/16/2002]
I agree with you about the heater question.
I think it should be on....even though the manual does not mention it.
Nice insight.
Now, if you're doing a system flush, then I would definitely run the heater to purge the old coolant. :yesnod:
Thanks for the quick replies, but now I confused. If you are changing coolant wouldn't you want to change all of it possible, i.e. have the heater on just as you would to flush the system? How do you purge the air from the heater core?
Another question, did you start the procedure with the car up to temperature, seems if you need to hold the rpm at 3000 for 30 seconds the block should have temperature?
Thanks again,
CarlB
The service manual procedure is geared towards a refill after service work requiring a radiator drain. This is what I did for my h/c job. Since I was just refilling the emptied portion of the system, I followed the manual's steps.
For a total flush, all the fluid needs to be replaced and that includes the heater core. So, yes, the heater needs to be flushed along with the rest of the system in this case. The air will be purged in the core along with the rest of the system as the fluid pushes air out during the cycling process.
I let the car warm up to the point where I felt comfortable revving to 3K before I started the procedure. All air appeared to be gone as the system is functioning perfectly.
Thanks for the info and your patience with my questions. I will proceed. As you have said in posts before "it's all in the details".
Happy Holidays [IMG][/IMG] :seeya
