I did a compression test on my lsx376 (like a iron block forged ls3 basically), which has 9.0:1 compression and got around 140 - 155 across the board. Is this ok?
I would say it's ok. Since the readings are pretty even. Was the engine warm or cold? How did you do the test? Big cam?
I think that sounds about right, did compression test on my 396 big block that is rated at 9:1 compression ratio, numbers were around 150 plus or minus.
Someone on a truck forum had some calculator that gives compression psi range expected with compression ratios, only thing was different camshafts could alter the numbers.
is the car n/a if so thats way to low. s/c is on the low end but will work. i don't know if its a new build but if it is i would ask builder why so low?? if cate why get low comp? your low end well suffer or ur running high gear ratio in the rear end to compensate for low comp. jmo over 35years building cars. if your happy how it prefromes then disregard everything i said. im running around 30 lbs boost at 9.75.1.
Make sure you do the test with the throttle body wide open. Only way it's really valid. Actual psi will vary, depending on cam. Two identical 9:1 compression ratio motors will yield much different numbers if one has a factory cam, and the other has a big cam. On a healthy motor, the more important number is that all cylinders read the same within 5 psi.......
140 is low. All plugs out, battery fully charged, and throttle fully open?
I'd like to suggest that the follow up is a cylinder leak down test. The two together will really tell you where you are.
Well there were some issues with the test I did unfortunately. I later realised there was an o-ring for the compression tester fitting (assume it seals in the spark plug hole?). Did not have this on when doing the test :/ Also, I did not have the tb held wide open (forgot). And the motor does have a mild (stage 1) cam apparently but we haven't got a clue what it is... Also this has a Maggy on it so I dunno if that would affect it...
heard the throttle wide open thing too I dont see how that affects anything .The cyl will get the air it needs either way.
150-60 for a low comp engine is just fine nothing to worry about. If you really want to know its health do a leakdown test.
Warm engine. All the plugs out.
and yes, you need that Oring
Its 9:1, cam has some overlap. Those numbers sound fine to me. Spread is a little high, but w/o that Pringle’s to seal the tool to the plug hole, all bets are off.
Holding the throttle open helps.
Disconnect the injectors.
Id do it again
Hi, yes I talked to a few guys who build race cars and one who is a Corvette guru (BlownBlueZ06 on here) and they all thought the numbers were just fine for that motor. I'm checking it because the engine suddenly leaned out one day on a test drive (was trying to fix a low rpm hesitation / stumbling at sudden WOT) and although I let off, it broke some of the porcelain on the plugs and one had part of the ground strap gone :o eeek!!
I checked the cylinder bores with a borescope and did not find any damage just what appears to be some detonation marks. I was told the pieces either disintegrated from the heat / managed to go out thru the exhaust. Thats why I did the compression test. I really want to pull the heads and check although the car is running like it was again except I can hear a very slight tapping sound from the heads....
