C5 Traction Control Issue
Old Jun 18, 2021 | 11:37 AM
McAwesome's Avatar
McAwesome
5th Gear
Default C5 Traction Control Issue
So, had my tires rotated and an alignment this week. Drove it home (less than a mile) and parked it in the garage. Today I drove it to work and about 3 miles in all of a sudden the Traction Control was engaged and slowing the car. (I hope it goes without saying that there wasn't any issue to cause this...dry weather conditions and I wasn't pushing the car hard.). Disengaged traction control to allow me to drive it home. Any thoughts/ideas would be appreciated. Not sure if the alignment would have caused a problem? (Seems weird that it would) but have not had this issue before.
Thanks in advance!
Old Jun 18, 2021 | 01:18 PM
feeder82's Avatar
feeder82
Rotated tires? are you running the same size on all four corners? see if you have any codes off the dic
Old Jun 18, 2021 | 01:20 PM
mmartinez's Avatar
mmartinez
Might check your wheel speed sensor wiring and connectors being that you had an alignment and tire rotation done.
To C5 Traction Control Issue
