ignition switch replacement c5
Old Jun 19, 2021 | 07:20 AM
sargedel's Avatar
sargedel
Default ignition switch replacement c5
After replacing the ignition switch, does the car need to be reprogrammed???
Old Jun 19, 2021 | 07:48 AM
xlst's Avatar
xlst
No, just simply replace it and its good. Center piece, where the key goes, is reused.
Old Jun 19, 2021 | 05:06 PM
Mastertvtech's Avatar
Mastertvtech
I spent the extra money and bought an OEM, which was pictured with a green housing in the rear, but arrived all black, china unit in GM box....It was defective. Tried re-springing it and it worked 3 days and then started intermittently doing weird things. Bought a second one and it too has issues. Now I am going to service my OEM. I have read many others have had similar results.
Old Jun 20, 2021 | 02:08 PM
Moved to C5 Tech.
Old Jun 20, 2021 | 02:20 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Where did you purchase your OEM switch ???
Old Aug 7, 2021 | 09:16 PM
dcm0123's Avatar
dcm0123
5th Gear
The same problem.
The AC/Delco OEM "Made in China" version from Amazon was defective right out of box- starter contact has no power. Someone actually made a video on YouTube showing how to repair the no start issue caused by poor manufacturing. Will be sent back.
Where can you buy an OEM Switch?
Old Aug 7, 2021 | 09:25 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by dcm0123
I have the same problem.
The AC/Delco OEM "Made in China" version from Amazon was defective right out of box- starter contact has no power. Someone actually made a video on YouTube showing how to repair the no start issue caused by poor manufacturing. Sending mine back.
I bought mine from Rock Auto !!
Old Aug 7, 2021 | 09:56 PM
Smoken1's Avatar
Smoken1
Suburban Chevrolet in Oregon and i'm sure many other places
https://www.trunkmonkeyparts.com/oem...witch-10308321
Old Aug 7, 2021 | 11:46 PM
herwawan's Avatar
herwawan
I just installed mine today, same with the black back and made in China inscription. I haven’t driven the car yet but all functions are OK and it fixed all my issues yet. Also car starts right up.
Maybe a bad batch? I ordered mine yesterday, delivered today.
re-the video how to fix the part though, feel free to share how to do it. I’d like to try on my original defective part.
Old Aug 7, 2021 | 11:53 PM
C5 Diag's Avatar
C5 Diag
So your new switch fixed your issue ??…if it did please let everyone know on your post yesterday so that we know we have a fix !!
Old Aug 8, 2021 | 12:29 AM
herwawan's Avatar
herwawan
Yes!!! I did update my thread with the new ordered from Amazon like the others and posted a short video. I am curious to know if these non-functional parts are just a few bad items or something else.
Old Aug 8, 2021 | 04:34 PM
dcm0123's Avatar
dcm0123
5th Gear
Video
Old Aug 8, 2021 | 04:36 PM
feeder82's Avatar
feeder82
The most counterfeited thing sold on Amazon is auto parts. buyer beware
Old Aug 9, 2021 | 01:29 AM
Castor's Avatar
Castor
Now I'm worried. Just received a week ago new GM switch. Also arrived all black, china unit in GM box... Hope not defective.
Was not planning to change it now, but - after reading this - will do over weekend to check - not to miss return period...
Old Aug 9, 2021 | 12:36 PM
Mastertvtech
At a minimum, I would test the contacts with a meter like the video shows.....My OEM that I serviced has been working flawlessly
Old Aug 10, 2021 | 03:21 PM
herwawan's Avatar
herwawan
I received the new one from RockAuto. Unfortunately, it's the same black housing Made in China...
Old Aug 11, 2021 | 06:28 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
So did I, about 3 weeks ago.....
I understand, and have understood this for quite a while. HOWEVER, how do you insure that you're not getting counterfeit stuff, when you go through legitimate sources, NOT some unknown e-bay seller? And, the package has "Genuine GM part" stamped all over it....
Same for me. A month ago, my car started throwing several DTCs, most of which were tied to the EBCM, but a couple that also COULD be tied to the ignition switch issues that have been discussed here, at CF, for a number of years. So, I removed the EBCM, sent it out to ABSfixer, and after re-installation, the car is good again, with no messages flashing on the DTC. Therefore, I wasn't looking forward to pulling the console apart, followed by the lower dash components, to change the ignition switch, especially if the car has been running well. And if the switch is indeed questionable, I don't want it sitting on my shelf, when it needs to be sent back....
Old Aug 11, 2021 | 06:35 PM
leadfoot4's Avatar
leadfoot4
Mine looks just like that one, and unfortunately, I bought it a couple of weeks before I thought I did, and my return date passed, a week ago. Secondly, I saw the original post about disassembling the OE switch, by popping the green cover, and accessing the contacts for testing/cleaning. Looking at the new one, with the black cover, I don't see any obvious places, where you'd disengage any tabs to open it up. Maybe I'm just not looking at it correctly....
Old Aug 11, 2021 | 07:42 PM
herwawan's Avatar
herwawan
At this point we can assume these are the new units moving forward. Amazon & RockAuto are shipping it.
Maybe best is to try to fix or original units, although I’ll just keep the one from Amazon in for a while and see what happens. I’ll keep the second unit from RockAuto in the car in case something ever goes wrong on a long trip, and I’ll see how to repair the original one in the meantime.
To ignition switch replacement c5
