Fuel Pressure High - Drops at High Load
There's no reason a 255lph pump won't work for a 500HP NA engine. I replaced the regulator/filter, got a pressure gauge and measured at the rail. Seeing 65psi during run, drops to 55 at engine stop and stays there, doesn't seem to be a leak. Third dyno pull, still a problem.
Took out the pump and checked the lines, everything looks good. Checked the lines from the regulator to the pump, nice and round, blew through the lines, no blockage. Replaced the whole fuel line with steel braided, added an electric fuel pressure sending unit and installed the gauge in the dash, now seeing 72psi running (hmmm.. that's high). Went out for some pulls and noticed a slight drop on short WOT runs but never got below 65psi (I won't risk my license to test it out to redline 4th the way it's done on the dyno). Fourth dyno pull - guess what - still the same problem. Not as bad, but he won't run it past 5500 rpm because AF gets into the 13s and duty cycle is over 120%. Decided to track down this high PSI issue, must be part of the same problem.
Replaced the regulator again, still seeing about 70psi running. Installed a direct voltage wiring kit for the pump. Now seeing 75-80psi running (hmmm... that's really high). And as the pressure increases, the car is harder to start. It turns over forever and fires off randomly until it finally settles into idle. Took the pump out of the tank again and checked everything. Cleaned off the return line on the sending unit and tried blowing through it. Seems like there's an obstruction, sounds like a trumpet. I removed the sending unit from the pump canister and popped off the end of the return line. Under there's a small piece of red plastic on the end of the tube. I pried it off and replaced the end cap. Now there's no obstruction in the line. Why would that be there from the factory?. Left the new wiring kit installed, figure it can't hurt.
Refilled the tank, started up, it started hard again, and shows 75-80 psi running. What could be keeping the regulator(s) from working? It regulates by dumping gas down the return, and I've confirmed that there is no blockage there. The lines will only connect one way at the regulator, and I've confirmed they're correct (green/blue/black). If you guys have ever seen the pump, the return line is on a spring that allows the pump to move around on a hinge, the tube moves in and out of a grate with an end cap on the underside of the sending unit. What's the reason for all that? Could it still be blocked in some way by that mechanism? I won't try another dyno pull until I get the pressure regulated at least. - Thanks for any advice.
My set up for the pass 12yrs is it primes to 60 then when i shut it off goes to zero. litery before i even turn the key on i'm at 60 and never had an issue. i guess what im saying is losing psi should not be an issue. i forgot r u using the stock return line??
but if u thing about it, thats what mine is doing i have no check valve if i don't start the car it immediately. it drop to zero in a few seconds. see what in getting at it should hold to start. and for some reason when my car gets really hot it takes about 3 primes to get to 60. literary between primes my psi drops if i dont go fast enough, but im going to bust my brains to think what's going on i mean wtf it only a stupid fuel line. sorry might have missed this but when did it start happening?
when it does prim the second time u shoudl check the volts.
I put the first replacement back in, now I'm back to a solid 72psi no matter what, and it holds pressure all day. I put the mechanical gauge back on the rail and compared it to the electric, and the electric is 5psi higher across the board. So, that means I'm really at a constant 67psi which seems much better. I hope with the hotwire kit it's able to keep up the flow on the dyno, which was the reason for starting this whole damn process.
