Gone through 3 serpentine belts in short period !!! Drive pulley is not wobbly nor are any other pulleys. Belts are continental gatorback. New tensioner and pulley were put on. After 2nd belt I showed mechanic that belt didn't seem to be centered. He said that it was fine. Each belt in the last 2 weeks started tearing and it appears the belt coming up to the tensioner is out of alignment with the drive pulley. Are there specs as to how to install the tensioner? Need to solve this problem as I am totally pis sedan at this other mechanic who has already screwed me out of $500!!!!!!
didn't see your response. I know you helped me before with my 94 convertible. Maybe I am not looking in the right place. I'll not to good with these threads and post and such. Sorry
Send me your email address and I can forward video of car running
just saying more eyes r better than one. when the community looks, the percentage to fix sky rockets. i'm not disrespecting anybody but that seems the best way to fix. if u dont want to cool.
I'm betting your crank pulley is coming apart. happen to have a video of it running?
Sounds about right. That, or someone didn't tighten the balancer correctly, and it's spun, then walked on the crank. I've had 2 serpentine belts on my car in 21 years, the original, and a new one around 7 years ago. Something is definitely amiss. I'd be curious what "pulley" was replaced. Good luck to you, OP....
