C5 shift problem
Old Jun 27, 2021 | 08:04 PM
Russ2018's Avatar
Russ2018
1st Gear
Default C5 shift problem
My 04 suddenly has no connection between shifter and transmission. I’ve been waiting for 4 hours for a tow company through AAA. Has anyone else had this shift issue and, if so, suggestions? It’s automatic.
Old Jun 27, 2021 | 08:11 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
A broken shifter cable is very common on autos.
Old Jun 27, 2021 | 08:23 PM
knewblewkorvette's Avatar
knewblewkorvette
Yep, cable has plastic end and they break over time.
Old Jun 27, 2021 | 08:39 PM
Smoken1's Avatar
Smoken1
You can buy new bushings for the cable Dorman 14057 is the part # IIRC
Old Jun 28, 2021 | 04:28 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I just had my transmission shift cable replaced...It was 18 years old and i do not recommend just replacing the bushing/bushings...it will not last as long as an original oem GM cable w/ pressed in bushings. For me, it is not worth getting stuck somewhere again. I was fortunate and mine happened at home.
I also bought a spare cable incase GM discontinues making the cable. ​​​​​​​
Old Jun 28, 2021 | 05:15 PM
Moved to C5 Tech.
Old Aug 1, 2023 | 07:29 AM
Niccolo's Avatar
Niccolo
Cruising
2024 C5of the Year Finalist - Unmodified
Happened to my C5 the day after I bought it, fortunately in my driveway. The bushing joining the shifter with the cable rotted out. I replaced it myself with a Dorman bushing kit - $17.
To C5 shift problem
