Easy entry seat
Old Jun 30, 2021 | 06:05 PM
vetorama's Avatar
vetorama
Default Easy entry seat
I have a 99 frc and every time I use the key fob to enter the car, my drivers seat moves back to the farthest position. I have tried setting the seat memory on the door and nothing changes. Can i pull the fuse for the door memory so i can use the key fob.? If i manually lock, seat stays where i want it.
Turns out, my car does not have the memory option, don't know what I was thinking. Still, when I use the fob to open the door and then put the key in the ignition the seat moves all the way back. Its a real pain as then I can't push the clutch all the way in to start the car unless of course I move the seat every single time. Easy entry is turned to off and does the same thing with both key fobs.
Old Jun 30, 2021 | 06:08 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
There is an option to turn off the easy entry seat through the options. Your manual will tell you how. I would but I can't remember. It is through the options button on the dic.
Old Jun 30, 2021 | 06:10 PM
vetorama's Avatar
vetorama
Default Seat
Tried that and does not work, like a gremlin no matter what, keeps doing it.
Old Jun 30, 2021 | 06:22 PM
popshumphrey
St. Jude Donor '16
Wow. Of course the car is made by Gremlin Motors. Mine just turned off fine.
Old Jul 4, 2021 | 04:37 PM
rrwirsi's Avatar
rrwirsi
My easy entry is turned off but every time I use the key fob the seats still move. So to stop that, I used the key entry only. Worked well for several years but recently, without any changes, when I use the key the seat move again along with the mirrors. I then set the set memory to where I want the seats. So far that has fixed the problem with both when I use the key entry. The electrical gremlins in the C5 have no explanation. .
Old Jul 7, 2021 | 03:04 PM
RPGR90s's Avatar
RPGR90s
Default Seats
My '00 Vert does the same thing. I've used the memory on the left door panel to set position 1 for me and 2 for my wife and no matter what, either key fob places me in position #2. I've learned to live with it. Maybe the next time I disconnect the battery I can get it resolved.
To Easy entry seat
