DIY tutorial on installing differential and transmission
Old Jul 10, 2021 | 12:37 PM
z06801's Avatar
z06801
Default DIY tutorial on installing differential and transmission
Does anybody have or know of a good one either video or written photos. I should be getting my differential back from RPM this week and would like to do it myself. I have access to lifts and tools just don’t want to miss something important. The car currently has the torque tube and clutch in place.
Old Jul 10, 2021 | 12:55 PM
Autoeng's Avatar
Autoeng
If you find my thread on my diff upgrade I have a couple of links to install threads in it that helped me do a successful removal and install.
Old Jul 10, 2021 | 02:41 PM
feeder82's Avatar
feeder82
here's a pdf with pics
File Type: pdf
Old Jul 11, 2021 | 12:04 PM
z06801's Avatar
z06801
Thanks guys that pdf is great I can definitely handle with that as a reference.
Old Jul 11, 2021 | 01:40 PM
rjacobs's Avatar
rjacobs
not hard.
Stab the trans first, then stab the diff to the trans. Much easier that way then trying to stab it as one piece. The trans you can stab with the torque tube basically in its normal position, then you can use the weight of the trans to tilt everything down into place to give you room to stab the rear diff... If you try to stab the trans and diff as a unit, you have to man handle the torque tube down at the right angle to get it all stabbed on.
Make sure to keep track of where your wiring bundle is going as you put things back into place and re-secure it. First time I put my car back together I think I had the wiring bundle running down the wrong side of the top of the trans and when I stabbed the rear end I realized it. It runs down the passenger side, not the drivers side.
Old Jul 11, 2021 | 02:29 PM
z06801's Avatar
z06801
Originally Posted by rjacobs
not hard.
Thanks for the tips! I was wondering about that and probably would have stuck them together first, so good to know. A race shop at the track took it out, so I didn't get to see how it all goes back. They put the cradle back up so it could roll so I'll just have to remove that and the tunnel plate and it should be ready to put back
Old Jul 11, 2021 | 05:05 PM
rjacobs's Avatar
rjacobs
just remember...NO IMPACT TOOLS ON THE CRADLE BOLTS...
Ive had my driveline apart so many times I can have the diff sitting on the ground in about 2 hours.
Put the mufflers back in before the cradle/suspension/axle shafts also.
Old Jul 12, 2021 | 02:06 PM
z06801's Avatar
z06801
Copy on the impact tools, are there torque specs on the cradle?
Old Jul 12, 2021 | 10:55 PM
rjacobs's Avatar
rjacobs
I think its 81 ft. lbs off the top of my head.
There is a PDF around here somewhere that has a huge list of all the torque specs.
I try to follow them unless I cant get my torque wrench in which happens in tight quarters.
Old Jul 13, 2021 | 12:02 AM
Smoken1's Avatar
Smoken1
This one?
File Type: pdf
Old Jul 13, 2021 | 12:06 PM
z06801's Avatar
z06801
Thanks for throwing that up, printing it of for reference
To DIY tutorial on installing differential and transmission
