A/C recharge - low / high side question ?
99 C5 here. I have owned the car since 02. A/C has never been serviced. A/C started blowing warm last year. A few days ago I attempted to add refrigerant myself after reading a bunch of threads here, especially the "Ac 101" one. I rented a A/C manifold gauge set and picked up one can of r-134a. I added about 10 oz and the passenger side was cold but the center and drivers side was still warm. It was getting late so I decided to disconnect the manifold gauge set and ended up with a small leak from the low side schrader valve. I blipped it a few times but no improvement. Next day I had the evacuation done so I could replace the schrader and investigate further.
Yesterday I rented a vacuum pump in addition to the manifold gauge that I already had. I also picked up a new schrader valve, (3) 12 oz bottles of r-134a plus one bottle of dye with a quick charge adapter. I replaced the schrader and connected the vacuum pump to the charge line on the gauges. With the vacuum applied, I opened both the low and high side valves on the gauges. I let this run for about 45 mins or so. After this I closed the low and high valves on the gauges. I let this sit for about 45 mins or there was no noticeable of the vacuum on either side of the gauges.
I then proceeded to charge the system. I connected my first can of r-134a to the charge line and opened the valve on can to allow refrigerant to enter the service line. Since a vacuum was still present on the low and high sides there was no need to be concerned with air in those two lines. I did however bleed air from the service line by unscrewing the hose directly connected to the gauges for a second or so to remove air from that line. With the car still off, I opened the low side valve on the gauges. Once the flow started to slow down I went ahead and started the car. At this point the compressor turned on as there was enough refrigerant in the system to do so. Once the can was empty I turned off the car closed the low side on the gauges and then the valve on the low side service port.
I then proceeded to put in one charge of dye on the low side service port directly. With the car running, I put in "one shot" or 3 seconds of dye into the low side service port. My next step was to put in the second can of r-134a. With the car off, I connected the low side hose from the gauges back onto the port. Since I was worried about air in the line on the low side, I connected the vacuum pump back to the service line on the gauges. With a vacuum applied, I opened the low side valve on the gauges while leaving the low side valve on the service port closed. After a few seconds I closed the low side valve on the gauges and then disconnected the vacuum pump.
Now with air removed from the low side hose, I connected my second can of r-134a and proceeded to bleed the air from the yellow service line as I did before. Once this was complete, I started the car and proceeded to put in the whole second can of r-134a. The air from center was cold at this point. It was late and I decided to stop for the night.
This morning with the gauges still connected, there was a static pressure of about 75 psi on both the low and high sides with car engine at room temperature. The temperature today in Chicago is about 66 degrees with 90% humidity. I am working in a garage with both the side and service opened so maybe it is a few degrees warmer at most. I started the car and turned the A/C on to the lowest temperature setting, fan on high plus I had a thermometer in the center vent. Recirculation was on. After about 3 minutes I proceeded to check the pressures. At 1000 rpm, I read 28 psi and 235 psi on the low and high side respectively. I also checked at 2000 rpm and got about 26 psi and 265 psi on the low and high side respectively. The center vent temp was around 38 degrees or so.
I realize it is not an ideal day to check A/C performance but how do those pressures look?
Doesn't the high side seem excessive?
I am tempted to put in more refrigerant simply for the fact that there is no way I could have put 1.5 lbs or 24 ounces in especially after purging air from the yellow service for both of the cans. I would expect there to be about 2 - 4 oz lost during that step. The center temperature does seem cold though.
Any thoughts?
