Gauge cluster lights out
Old Jul 19, 2021 | 07:48 AM
Bob__zombie's Avatar
Bob__zombie
Default Gauge cluster lights out
Installed LED headlights. Went to drive it and the gauge cluster lights weren't working. Checked the fuses that usually go out and they're fine. The dimmer isn't turned down and when I try that, even the little MPH inside the cluster works/adjusts. Did I miss something during this install or is there something else?
Old Jul 19, 2021 | 11:11 AM
oelarse's Avatar
oelarse
These two High Voltage UV lights on the sides of the cluster gives the cluster illumination . The may be gone or the powersupply .
You can connect external powersupply shown below to verify the cluster illumination
