C5 DIC not responding to C2 guy
I am not familiar with the Anti-locks, but found some articles on bad solder joints in the anti-lock control box. I prefer to get the codes before I go there and find it to be a wheel sensor instead.
I have a cheap OBD II reader, but the plug seems to be larger than that on the C5. Any help would be appreciated.
Ron
Ron
The "diagnostic display" mode is entered with the following procedure:
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10second period.
Initially the onboard diagnostics go into the "automatic" mode which shows each module's DTCs in a preset sequence:
10 PCM Powertrain Control Module
28 TCS Traction Control system ABS
40 BCM Body Control Module UTD
60 IPC Instrument Panel Cluster
80 radio
99 HVAC Heater VentAir
Conditioning
A0 LDCM Left Door Control module
A1 RDCM Right Door Control Module t
AC SCM Seat Control module
B0 RFA Remote Function Actuation
