Seat motor running
Old Jul 24, 2021 | 03:54 PM
akbeaver's Avatar
akbeaver
Default Seat motor running
Having a problem with the right seat motor running uncommanded at odd times. Usually at shutdown it will run for about 4-5 seconds, then stop. The seat position does not change.
New occurrence. Tried to start car but battery down. Charged battery and heard seat motor running. Apparently it had caused the battery drain.
anyone else had this issue?
Old Jul 24, 2021 | 10:15 PM
Ed Ramberger's Avatar
Ed Ramberger
There are many threads on the switch draining the battery. Google c5 power seat switch motor draining battery
Old Jul 25, 2021 | 12:27 AM
jim993's Avatar
jim993
Or simply- "battery drain"
Your car is presenting symptoms similar to what mine did when the driver side seat switch failed. I initially solved the problem by pulling both seat circuit breakers in the passenger side footwell fuse center. Later installed a new seat switch on the driver side.
To Seat motor running
