C5 Corvette T56 Shifting issue
Old Aug 2, 2021 | 07:11 PM
Josh427SS's Avatar
Josh427SS
Default C5 Corvette T56 Shifting issue
Hey guys, I have this issue with my C5 and was wondering what it could be or if anyone has had this happen to them before.
I have a '00 FRC with the t56 manual and only 51k miles on it. Last month while I was leaving work and just cruising back home, it was really hard to get out of third gear and It didn't let me go into any other gear. I could only use third and neutral so I drove it home in third gear. Even with the car turned off and regardless if the clutch is pressed or not, it will only let me go into third gear and I have to really force it into fourth but it'll go into fourth. I did discover last night however that once it's in fourth, it will let me go into 1st/2nd/5th/6th/reverse but it's still real hard to get into those gears. Once it goes back into third, it's once again extremely hard to get back into fourth and it also won't let me go side to side into first/5th etc. I would have to force it into 4th then it'll let me go into those gears. when the issue happened it didn't make any noise, it just happened. Has anyone ever had this issue before or have any idea what it could be? thank you
Old Aug 2, 2021 | 08:12 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Sounds like something broke internally. There are a few snap rings in the T56 that can break and play hell with gear alignment. Unfortunately, it's likely going to be time for a rebuild.
Old Aug 3, 2021 | 07:51 AM
oharal's Avatar
oharal
Is this the case only when the engine is running or even when you are just parked with the engine off?
Old Aug 3, 2021 | 09:52 AM
Josh427SS's Avatar
Josh427SS
i haven’t tested shifting it when the car is running but it didn’t let me get into fourth when I had to drive it home. I also didn’t attempt to force it into fourth.
Old Aug 4, 2021 | 12:04 AM
MetalMan2's Avatar
MetalMan2
The 3rd/4th shift fork in the typical T56 is cast aluminum and is notoriously weak (though in reality this is a non-issue for the vast majority of T56 transmissions). The Viper's T56 got a steel 3/4 shift fork. Recently when I rebuilt my transmission I dropped in a steel one (it's plug-and-play).
I don't have much experience with the symptoms of a failed 3/4 shift fork, but it may be worth looking into.
Old Sep 9, 2021 | 10:39 PM
Josh427SS's Avatar
Josh427SS
Ended up being a shattered 3-4 shift fork. Put a steel 3-4 fork in it so hopefully it wont do that ever again
Old Sep 10, 2021 | 08:00 AM
oharal's Avatar
oharal
That will do it!
Old Sep 10, 2021 | 10:12 AM
helga203's Avatar
helga203
Old Sep 10, 2021 | 03:52 PM
MetalMan2's Avatar
MetalMan2
Glad you got it fixed AND upgraded! Also glad that your unfortunate real-world experience justified the $45 I spent to replace a stock non-broken 3-4 shift fork.
Gotta say it... I CALLED IT. lol.
To C5 Corvette T56 Shifting issue
