Low oil level message
Old Aug 5, 2021 | 06:38 PM
wgm1993's Avatar
wgm1993
Default Low oil level message
does anyone know how low the oil has to get for the dic to trigger the “low oil level” message? i have an oil leak so i know the car isnt wrong but i was just curious on the exact amount of oil its missing
Old Aug 6, 2021 | 10:37 AM
oktx's Avatar
oktx
Pull the dipstick and look.
Old Aug 6, 2021 | 11:22 AM
grinder11's Avatar
grinder11
Thank goodness GM hasn't taken the engine oil dipstick away, like they have the trans fluid dipstick.....I believe the low level warning is when you're approximately 2-1/2qts low, so if that's the case, it may be low enough that it may not even show on the dipstick.......
Old Aug 6, 2021 | 11:25 AM
acroy's Avatar
acroy
I had that happen once and IIRC no oil showed on the dipstick Yes I think it was about 2.5qt low.
Old Aug 6, 2021 | 06:30 PM
wgm1993's Avatar
wgm1993
yes obviously but i just wanted to know the exact amount that GM set the cars computer to trigger the message at
Old Aug 6, 2021 | 06:34 PM
wgm1993's Avatar
wgm1993
2.5 qts sounds about right
To Low oil level message
