My clutch/slave may be going out...
Aug 5, 2021 | 07:58 PM
2024 C5of the Year Finalist - Unmodified
Hi gang,
When I do a little "spirited driving", my clutch pedal is fine when I start out, I shift to 2nd and the pedal free play come in at about 1/2 pedal and stays about the same for a short period of time and then slowly returns to normal. The normal free play is very minimal. I have flushed the clutch completely and no real change. Looking for some advice.
Thank you!
Aug 5, 2021 | 09:40 PM
Replaced this several time so I can help but if you already bleed the clutch line then you may need t replace it..
Aug 5, 2021 | 09:50 PM
Sep 13, 2021 | 08:08 PM
Anybody have any ideas on my issue?
Sep 13, 2021 | 10:56 PM
https://ls1tech.com/forums/manual-tr...-write-up.html
Long read, skip down to 'What is drill mod?' and then ' Next step is to replace your clutch master cylinder'.
Drill mod works in most applications.
Sep 14, 2021 | 04:40 PM
Quote:
Originally Posted by
purrvert
Thanks... One question, I'm going to assume that you need to do a FULL bleed on the system after this is done?
Sep 14, 2021 | 06:04 PM
uit
stangyog
Get a new clutch if u have a ton of miles on it.
Sep 14, 2021 | 07:32 PM
helga203
My car has 74,000 +/- miles on is I am gonna do a clutch in a year or 2, but was just looking for an alternate fix in the meantime.
Thanks!!
