Thermostat
Old Aug 7, 2021 | 03:11 PM
Joe Babish's Avatar
Joe Babish
2nd Gear
Default Thermostat
I have a 2001 coupe I recently had the water pump replaced and the coolant system flushed. I am now noticing that the temperature gage will climb up to 220 -230 at idle. Should I have had a new thermostat put in when the water pump was replaced? Prior to the water pump issue the temperature gage would read 200 - 210 degrees at idle.
Old Aug 7, 2021 | 03:52 PM
Autotragic's Avatar
Autotragic
Originally Posted by Joe Babish
I have a 2001 coupe I recently had the water pump replaced and the coolant system flushed. I am now noticing that the temperature gage showed 210 degrees and will climb up to 220 -230 when at idle. Should I have had a new thermostat put in when the water pump was re placed? Prior to the water pump issue would the temperature gage would read 200 degrees. I have had the car for 12 years.
Well on these engines the thermostat housing bolts onto the water pump itself, the original design had it as one integrated unit. I don't know any competent mechanic that would replace the pump and not the neck or thermostat or at least inform the customer that it's a mighty good idea.
Stock thermostat opens at 187° and fans are set to start at well over 200° and the high speed fan at something like 235°. I'd replace it if it was me and I did when I had my water pump replaced.
Old Aug 7, 2021 | 04:29 PM
jcgunn's Avatar
jcgunn
Before you start throwing parts at it, follow the procedure to burp the air out of the cooling system.
Old Aug 7, 2021 | 05:04 PM
Moved to C5 Tech.
Old Aug 7, 2021 | 05:19 PM
RonSSNova's Avatar
RonSSNova
Yes, it’s critical. These things can be tricky to fill properly.
To Thermostat
