air bridge to maf sensor seal
Old Aug 8, 2021 | 09:34 PM
jeff7251954's Avatar
jeff7251954
Default air bridge to maf sensor seal
Removing a aftermarket air filter assembly and going back with stock oem system on "04z. The air bridge slides over the maf sensor and is tightened with clamp. The plastic bridge seals to the plastic sensor. How does hard plastic against plastic seal without leaking? Is there a missing o-ring? Thank you.
Old Aug 8, 2021 | 11:14 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
The stock air intake has no plastic to plastic connections as far as I remember. I know the vararam does have a plastic interface on their air bridge in the configuration that places the MAF next to the throttle body.
Old Aug 8, 2021 | 11:54 PM
joeflyer's Avatar
joeflyer
There is no seal. It's a tight fit. I squirt some isopropyl alcohol on the parts before mating them.
Old Aug 9, 2021 | 07:56 AM
jeff7251954
That's the answer.
Thanks Joe
To air bridge to maf sensor seal
