TCM relearn/rest procedure
Old Aug 10, 2021 | 12:30 AM
Chad Bergeron's Avatar
Chad Bergeron
Default TCM relearn/rest procedure
i just had my 2002 transmissions swapped with a 2004 transmission and for the most part, it runs pretty well but all the shifting is kinda wonky. i cant go beyond 85ish or it just hits rev limiter. if i cruise at 45ish, it constantly shifts back and forth between whatever 2 gears its deciding to shift between. and a lot of times it just seems like every gear shifts waaaay earlier than it should. my brother had suggested i try to do a tcm relearn/reset to see if that might be a nice simple fix for this. can someone provide the process or a link to the process of completing this task?
the transmission model is 4L60E
