C5 Radio/CD does'nt work
Old Aug 13, 2021 | 10:41 AM
Cedric5's Avatar
Cedric5
1st Gear
Default C5 Radio/CD does'nt work
Hello,
My battery being completely empty, I replaced it with the same model. Since then, my original radio and CD player have stopped responding. When I press the buttons, apart from RECALL and HOURS / MINUTES, nothing happens .... My 12-CD changer in the trunk works, it loads CDs well. The screen gives me the time as well as the logo of a CD at the bottom right. No LOC, SEC or ERR visible. I tried unplugging the battery for 5 minutes and plugging it back in, nothing. I removed and replaced the fuse, nothing happens either .... Everything works in the car except the radio and the cd player which does not respond.
Have you ever had this situation? Unless I am mistaken, I cannot find a person in my case on the various forums that I have visited.
Old Aug 13, 2021 | 10:48 AM
Moved to C5 Tech.
Old Aug 13, 2021 | 11:44 AM
BryceU_C5's Avatar
BryceU_C5
Originally Posted by Cedric5
Hello,
I have not had this problem, however my guess is that something is wrong with a logic board in the radio. It could be something as simple as a blown capacitor or a faulty resistor. IF you have the technical knowhow to troubleshoot which exact circuit component is faulty you might be able to solder in a new one.
However, I would personally take this problem as an excuse to replace the radio with a new head unit that has Bluetooth, AND a CD player. Crutchfield has a great selection and will recommend the correct hardware/wiring harness adaptors. Just don't cheap out on a new one. A cheap head unit will likely have lower sound quality than the stock head unit.
Old Aug 13, 2021 | 02:53 PM
rrwirsi's Avatar
rrwirsi
Never had the problem replacing 3 batteries in my C5, but just a SWAG, disconnect your new battery for about 30 minutes and reconnect. I am amazed how all the electronics are able to come back to life to normal after rebooting.
To C5 Radio/CD does'nt work
