Re: Do different size wheels with the same size tires make a difference? (WildKarrde)
It will change the handling, but not necessarily for the better. Generally speaking, the wider wheel will reduce sidewall flex, resulting in a harsher ride and quicker transitions. This may also cause a loss of traction on rougher surfaces. Minor changes like this can have big consequences, not all of which are good.
Re: Do different size wheels with the same size tires make a difference? (Duck916)
There has been a lot of topics on this in the past, some for, some against. Not sure myself, but when I spring for new wheels, I plan to go wider and spring for wider tires to best match the wheels.
BTW Duck916 - I love your mod list :lol: , that last mod will be done many times :cheers:
