on engine valve spring compressor?
Old Aug 16, 2021 | 09:49 PM
mgarfias's Avatar
mgarfias
Default on engine valve spring compressor?
I need some help finding something that'll work. Have a set of Mamo's new heads, and they're setup for 10mm rocker bolts. I have a comp cams on-engine compressor, but it is setup for 8mm bolts, and doesn't have enough meat to open it up to 10mm. Advice much appreciated.
Old Aug 17, 2021 | 11:50 AM
grinder11's Avatar
grinder11
You may be able to get a threaded insert (NOT a HELI-COIL!!) with an M10 external thread, and an M8 internal thread. IDK if they make something in the size you need. Just make sure if you go that route, you have a means to remove the insert from each thread you use it on/in!!
Old Aug 17, 2021 | 11:00 PM
RonSSNova's Avatar
RonSSNova
The trick flow has enough meat to enlarge the holes.
Old Aug 18, 2021 | 05:33 PM
mgarfias's Avatar
mgarfias
cool, thanks. I hadn't seen that one.
To on engine valve spring compressor?
