Intermediate Shaft Removal
Old Aug 17, 2021 | 01:45 PM
steveb's Avatar
steveb
Default Intermediate Shaft Removal
I had to replace the steering wheel position sensor on my 2002. The good news is that I was able to successfully replace my steering wheel position sensor. Got everything buttoned up and no codes. However, I noticed that somehow that I had goofed up reinstalling the grommet on the firewall. There is a seal piece that ended up on the other side of the grommet. To make a long story short, I need to remove the grommet so that I can install it correctly,
I could go back in and remove the column just enough to slide it off. However, it looks like it would be easier to just remove the intermediate shaft from the steering column to remove the grommet and seal. It looks like only two bolts to deal with. There is the bolt at the firewall which I had to deal with to remove the steering column and a bolt toward the steering box. If I have thought this out correctly, I should be able to loosen the bolts, turn the wheels straight, secure the steering wheel, remove the bolts, and slide the intermediate shaft off of the steering column. Could it be that simple or am I missing something? Thanks in advance.
