I'm looking at buying a 2002 vert from which I get the following codes: 40- BCM shows 5 codes, AO-LDCM shows 3 codes and A1-RDCM shows 5 codes. Which tells me there is a possible problem with the: body control module, left door control module and right door control module. I like to do my own work, so hopefully I'm only looking at buying parts.
What is my next step?
Thanks in advance.
Mark
First off you NEVER change a part because of a code…first determine what the code is and if it’s a current or history code…you then need to determine what sets that code and go from there !!
Would be nice to see the actual codes.
These things will throw all sorts of U codes which are comm errors for no apparent reason.
Do you have a Check Engine light?
Anything not working?
Thanks for your help guys.
How do I determine what the code is?
How do I determine whether it is a current or history code?
How do I determine what set the code.
Can I get the preceding info from the car's computer?
There is no check engine light.
Is the next step getting a diagnostic instrument?
How important are the door modules? The door locks and power windows seem to work fine. The trunk pops up and the fuel door opens with no problem.
The car starts with no issues.
My problem is that I really want to buy this car but not until I find out if the codes are significant.
Cheers,
Mark
Please ignore most of my last post. Just found out how to determine what the code is and whether it is history or current.
I have yet to find out what set the code.
cheers,
Mark
Cheers,
Mark
Best advice I can give you is use your smartphone to take a video of all the codes as the DIC scrolls thru them. Then you can do a search here, or on Google, to figure out what the numbers mean. There are 3 kinds of codes: C=Current, meaning there is a problem in that circuit/area. H=History, meaning there has been a problem sometime in the cars history. H-C=Current AND History, meaning the problem has existed sometime in history, and is still a problem. BTW.....Be prepared to find one heck of a lot of possible codes/scenarios when you search. Most important thing is to be certain of all correct numbers and letters displayed, which is why I suggested a photo of all of them, so you have an exact copy of actual codes displayed for reference......
cheers,
Mark
You need to obtain the Factory Service Manual to determine that…I wouldn’t worry to much about those codes…I’d concentrate on stuff like a compression test, harmonic balancer etc. and some other things…maybe if there is a Corvette Club in your area someone may be able to help or know of a shop that might help !!…hope the video helps.
And another video !!…by the way if a shop has a scope they can do a “relative compression test “ which takes 5 minutes to do vs. a few hours removing the plugs and doing one with a gauge !!
cheers,
Mark
Yea, you have 2 threads on this maybe C5 Diag can combine them for you
Thanks for the input guys. I just got back from checking the car again but more thoroughly this time. Didn't know that once you had found a code, you had to push gages to find out the code number. I found that all the codes are history. Problem with codes is solved.
Thanks again for the input.
Cheers,
Mark
I tried to erase the codes by tapping the "reset" button, it did not work. I'll do some further checking on another approach. The dealer let me take the Vette out a couple of times, for a total of about 1 hour with some highway driving. Runs beautifully. If all goes well I'll be buying it on Monday.. Been looking for a Vette like this all over the US and Canada for the best part of the year (Covid19 didn't help), then this car shows up a 5 minute drive from my house. Go figure.
Cheers,
Mark
Do the codes start with U or some other character such as P, B or C? U codes generally mean nothing unless there are a lot of them. If there are a lot of them you could have a battery issue or battery connection issue. Since you mentioned door codes there are several door codes that relate to battery voltage which point to checking out the battery and it's connections. Remember Corvettes have plastic bodies so clean and tight ground points and junctions become very important. As mentioned before a code doesn't mean a specific part needs to be replaced it only tells you where to look for the problem. There are diagnostic procedures for each code that help you find the problem.
Thanks Bill.
Both codes begin with a "B". I was thinking that checking and cleaning the grounds should be the first thing to do for my new Vette, now you've given me a good reason to get at it right away. I've got a couple of overviews of the locations of the grounds for a C5 from a Bill Curlee post some time ago so I should be able to locate most if not all of them. I'll buying a manual as soon as possible.
Before starting on the grounds, should I disconnect both battery terminals?
What should I use to clean the grounds?
After cleaning the grounds, should I coat the grounds with regular grease or dielectric or something else?
Cheers,
Mark
Thanks for the input. Time for me to do a Mea Culpa, the codes didn't erase because I didn't read the directions thoroughly. The directions say "push and hold the reset button", I pushed the reset button but did not hold it. Went back to the dealer's yesterday and did it again properly and presto, the codes have vaporized. I've checked for codes after driving the Vette and there are none. Did a battery drain test and it came out to 0.02 amps which from what I've read is where it is supposed to be. Today, I laid down my money and am now the happy owner of a 2002 Corvette. Cheers,
Mark
