Has anyone ever have a car suddenly pull 10 degrees of timing ? Engine is built. S/c heads cam. Etc. driving car after three hrs car lost power. Found it pulled a crazy amount of timing. Reflashed tune. Ran great. Decided to download tune manually ran great then after three hrs. It did it again. At a lose. Thx.
I was just cruising down highway around 75 /80 mph. Not getting on it at all. Had a long trip
Many parameters can pull timing and yes depending on the tune 10 can be pulled.
I have mine setup to pull 10*
I’m not sure. What tune is bn used. I was at a shop getting work finished up and attempted to go home. When it started running bad I got it back to the shop and that what they were saying. I was just curious if this has happened. I know nothing on tuning a car and I understand there is a lot of that goes into it.
