AC and Co0ling Fans
Old Aug 26, 2021 | 02:39 PM
narlee's Avatar
narlee
Default AC and Co0ling Fans
Just want to make sure I have this right in my head. This is concerning the air conditioning. When I start the car cold and turn on the AC the fans don't turn on automatically. It is only when the car is up to 185 degrees the the fan will kick in when the AC is turned on, is this correct. It is a 1999. Thank you.
Old Aug 26, 2021 | 02:47 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You don’t have it right in your head !!…when you turn the AC on when the engine is cold the cooling fans will come on…mine turn on automatically albeit at low speed !!
Old Aug 26, 2021 | 03:03 PM
narlee's Avatar
narlee
OK, even when cold they should turn on, thanks.
Old Aug 26, 2021 | 03:12 PM
C5 Diag's Avatar
C5 Diag
Yes !!…if my car sits overnight and I start the car and turn the AC on the fans turn on…are you having any cooling or fan issues ??
Old Aug 26, 2021 | 03:29 PM
narlee's Avatar
narlee
When I start the car cold no cooling fans come on. Well, not sure if the driver side fan comes on, hard to see for sure, trying to get a mirror positioned to see for sure.
Old Aug 26, 2021 | 03:39 PM
C5 Diag's Avatar
C5 Diag
Yes, the drivers side is difficult to see without a mirror…just look at the right side…don’t know your mechanical skills or what tools you possess so I won’t tell you how to diagnose it at this time !!
Old Aug 26, 2021 | 03:44 PM
narlee's Avatar
narlee
OK, if both should be on I have some checking to do. If I get stuck I'll get back to you for help. Thank you
Old Aug 26, 2021 | 03:51 PM
C5 Diag's Avatar
C5 Diag
Do you have a wiring diagram ??…first thing I’d check are fuses and maybe start swapping relays…you can use the horn relay for 2 of the 3 relays…the 3rd relay is a 5 bladed relay !!…if you have a jumper wire, a 12 volt test light that would be enough tooling for now !!
Old Aug 26, 2021 | 04:03 PM
3sACROWD's Avatar
3sACROWD
I usually use a piece of PVC pipe. You can hear the fan and feel the airflow. Just keep it away from moving parts.
Old Aug 26, 2021 | 04:05 PM
narlee's Avatar
narlee
Ok, I'm off to do that now but have to leave in a bit. Thanks for your help, I will be back but probably not until tomorrow. Thanks again
Old Aug 26, 2021 | 04:07 PM
narlee's Avatar
narlee
One more thing to make sure, both fans should be working when I turn on the AC.
Old Aug 26, 2021 | 05:18 PM
Cutlassmaster's Avatar
Cutlassmaster
Both fans will always be on together whether on low speed or high speed.
Old Aug 29, 2021 | 08:54 PM
narlee's Avatar
narlee
Ok, I'm back. What I have so far is the fuses are good, the relays are good, the fans both work. Cold start, AC on, after a few minutes the passenger side fan cycles on for a short time then goes back on and every few minutes cycles on and off.
Old Aug 29, 2021 | 09:15 PM
purrvert's Avatar
purrvert
Is the right fan at low speed? Did you observe engine coolant temp when fan cycled?
Old Aug 29, 2021 | 09:39 PM
narlee's Avatar
narlee
The car was about 160 degrees and the fan was high speed.
Old Aug 29, 2021 | 09:55 PM
purrvert's Avatar
purrvert
https://www.corvetteforum.com/forums...coming-on.html
Check my posts in the above thread. Mine would start in low but only right fan would go high.
At 160 it is condenser pressure triggering fans.
Old Aug 30, 2021 | 11:31 AM
purrvert's Avatar
purrvert
If your fans are not coming on in low it would appear to be relay 45 related. Sequence is A/C on relay 45 energizes at 185 deg or 219psi and stays energized {in this case because you don't have low speed fans} till 255 psi is reached and relays 43 and 44 energize bringing in high speed fans {in your case only right hand}. Relays 43 and 44 would cycle between 255psi on and 219psi off. I would remove relay 45 or fuse 49 and test run engine, I would expect the same results you are having now. Check that relay 45 is inserted in the proper direction.
To AC and Co0ling Fans
Old Aug 30, 2021 | 12:53 PM
narlee's Avatar
narlee
Thanks, I'll go do some checking and get back with what I find out.
Old Aug 30, 2021 | 01:04 PM
narlee's Avatar
narlee
Also want to add the I said earlier it came on high speed but got to thinking it was low speed so I went and double checked. Cold car ac on no fans on startup but a few minutes later the passenger side fan only cycles on and off on LOW speed. Sorry for the misstatement earlier.
Old Aug 30, 2021 | 01:31 PM
C5 Diag's Avatar
C5 Diag
Just want to let you know these relays are not “direction” specific…they can be inserted either way and work…try it with your horn relay !!
