When to replace shocks
Old Aug 30, 2021 | 09:23 PM
weidbody's Avatar
weidbody
Default When to replace shocks
So wondering if I need to replace shocks that are original. My 2002 Shocks are 20 years old with 60,000 miles. Thoughts?
Old Aug 30, 2021 | 09:55 PM
1wholikescars's Avatar
1wholikescars
I end to replace shocks for cars after 7-10 years, because they eventually give up the ghost even though they haven't done a lot of traveling. Each car I've done it in, regardless of how low the mileage, was noticeably improved.
So, after 20 years, yes, I believe they are done and should be replaced.
I believe the common suggestion is the C6 shocks (although now I can't remember off the top of my head if it's C6Z or not), but I am sure someone will chime in.
Old Aug 30, 2021 | 09:57 PM
weidbody's Avatar
weidbody
Thank you!
Old Aug 30, 2021 | 10:26 PM
Smoken1's Avatar
Smoken1
Yep, C6 Z06 shocks
Old Aug 31, 2021 | 10:41 AM
RPGR90s's Avatar
RPGR90s
As I have the same concern as the OP (2000 Vert, 65k, with original shocks) may I ask what part number is used for the C6 ZO6 shocks?
Thanks,
RPGR90s
Old Sep 3, 2021 | 03:12 PM
G_Loc's Avatar
G_Loc
Originally Posted by SweenyRod
Here are the part numbers for the c6z shocks. Do some price shopping on them. I bought these from summit which was the cheapest. A lot of people recommend Cultrag on here but I’ve found gene’s prices always much higher than everyone else.
Sadly the set appears to be about $367 everywhere. A seller on eBay claims that GM started enforcing MAP pricing as of November of last year. That being said, you're right about Summit - they currently have a Labor Day sale going on, bringing them down to $357.14 + tax
Old Sep 3, 2021 | 04:20 PM
G_Loc's Avatar
G_Loc
yeah, that’s an absolute steal for new c6z shocks. Do you think that’s expensive?
As far as performance mods go, no, they are not terribly expensive. But looking back at threads from 1-2 years ago, 4 shocks were going for ~$210-220!
Old Sep 5, 2021 | 08:57 PM
splattt7272's Avatar
splattt7272
My '02 has the "MagneRide electronic shock absorbers" on it. Way to mushy if I don't leave in the performance mode. Will the C6 shocks work as a replacement and do I still need to use the module to lie to the computer?
Old Aug 14, 2024 | 12:11 PM
Keyman57's Avatar
Keyman57
Default Rear shocks discontinued problem - what kit? C5 Hatchback 2004 85K
Hey C5 owners, I had my front shocks replaced in 2019. I go to AAA Auto and they said the sport/tour electronic shocks are Now disco'd by GM. Good thing as they were $1000 EACH!
They gave me part number 19431689 19431680 and said they are on ebay.
Is this the shock you all recommend or should I go with a part number (which I don't have) for for the C6 ZO6 shocks?
Any particular brands you recommend?
What KIT do I need since I had the electronic shocks. I'm glad AAA will put it all in as I don't work on my vet.
Here the link I was looking at. Sorry I'm clueless here but want to learn.
https://www.ebay.com/itm/28589706636...Bk9SR9yvwZmqZA
I also have a loose Right Rear Tie Rod, probably cause I gently hit a curb in a parking lot backing up.
Tie rod is $400 and $400 to install it. Is that Normal?
I've had my C5 14 years now and it's been great. Thanks in advance for your help!
Thanks,
RPGR90s
To When to replace shocks
