Headlights won't raise or lower
Old Sep 8, 2021 | 01:13 PM
3sACROWD's Avatar
3sACROWD
Default Headlights turn on but won't raise or lower
I’ve recently run into a problem where both of my headlights won’t automatically raise or lower yet the lights work. I’ve tried searching but the results don’t quite match my symptoms. Some have only one that refuses to cooperate, or doors function but lights don’t turn on, or the thread doesn’t provide a conclusion with their findings. I’m trying to determine if I should be looking towards the headlight control module or BCM or something other. Info is below.
Car
  • 2003 Z06
  • Sun Guns (installed 6+ years ago)
  • 4 HI wire harness (installed 8+ years ago)
  • Twilight sentinel installed / activated (8+ years ago)
Symptoms
  • Headlights won’t go up or down
  • Chime activates when door is open as if headlights are on
Diagnostics
  • Headlights work via MFS or Twilight Sentinel
  • Doors open smoothly when manually opened and no weird noises prior to problem
  • Turning on the high beams does not help
  • Pulled fuses 3 & 4 (engine compartment – L & R headlamp motors) which stopped the chime
  • Purchased new relay and swapped with #43 & #44 with no change
Thanks in advance for any and all help.
Frank
Old Sep 8, 2021 | 03:25 PM
rrwirsi's Avatar
rrwirsi
I recently had one headlight that did not raise. I jiggled the wiring harness to the headlight and wallah, it went up. Cleaned all the connectors and no further problem. Realizing having two headlights with the same wiring problem would be very usual, but Murphy's law sometimes happens.
Old Sep 8, 2021 | 03:36 PM
Corky Graff's Avatar
Corky Graff
1st Gear
I have a left (drivers side) headlight pump that's is bad, so I am going to replace both. I would like to install No Fault LED lights as well at the same time. Do I need a new headlight housing unit or can I just purchase pulps and replace. Factory lights are just adequate! Mine is a 2002 C5 coupe.
Old Sep 10, 2021 | 11:43 AM
3sACROWD's Avatar
3sACROWD
Moderators - Please delete this thread. It is a dead end.
Last edited by 3sACROWD; Sep 17, 2021 at 11:21 AM. Reason: Requesting thread deletion
To Headlights won't raise or lower
