99 FRC battery drain
Old Sep 10, 2021 | 03:22 PM
bracketshark's Avatar
bracketshark
Default 99 FRC battery drain
I sold my Arctic white FRC back in January 2021, I have just bought it back, kinda got sick when I sold it. When I had the car before the battery would be dead after a week or so when the car wasn't started, I never look for a problem as the battery was disconnected most of the time, this seems to still be a problem. The other owner did replaced the battery and alternator with new units thinking they might be the culpret. As I walked by the car last night, in my shop the side window was down I noticed the DIC light was on, although very dim. The unit was warm to the touch, I'm thinking this shouldn't be happening. Any Advise where I should start looking for the culprit or would this be normal? Thanks
Old Sep 10, 2021 | 07:07 PM
mmartinez's Avatar
mmartinez
The DIC illumination controll **** may be fully clockwise and past the point where it clicks over causing the DIC lights to be on all the time.
Old Sep 13, 2021 | 08:09 AM
bracketshark
Nope that ain't it.
Old Sep 13, 2021 | 09:53 AM
mmartinez's Avatar
mmartinez
It's never that easy, if proficient with DVM you should perform a current drain measurement while the car is off. With the DVM configured as a ammeter disconnect the negative battery cable and connect the meter in series with the battery terminal and cable, normal current drain should be 25ma after car has entered sleep mode should be around 15-20 minutes. I do suspect that there is a problem with the dash cluster unfortunately. I
Old Sep 13, 2021 | 10:47 AM
bracketshark
OK, I already know something is killing this $300 battery, and i know the DIC light doesn't cut off although its very dim and warm to the touch. Any Idea what tells the DIC to power down? With all of this said, I did install a newer model C5, Z06 cluster in this 99 FRC about 6 or 7 years ago. The cluster is separate from the DIC, you think this might be the culprit? I have the original Cluster, it was a bitch to change. Thanks for the input...
Old Sep 13, 2021 | 11:42 AM
mmartinez's Avatar
mmartinez
It could be a incompatibility problem with the newer cluster you installed maybe somebody with more knowledge about this will chime in. The BCM is what controls the cars systems to turn on and to shutdown after a predetermined amount of time and enter what we call sleep mode
Old Sep 13, 2021 | 02:38 PM
bracketshark
Thanks for your input.
Old Sep 16, 2021 | 05:04 AM
oelarse's Avatar
oelarse
Try to measure the mV over each fuse in engine room and passenger footwell
shown in this video to identify which fuse has a abnormal current draw
Old Sep 16, 2021 | 03:26 PM
itsforfun's Avatar
itsforfun
Never overlook a Ground problem with Corvettes. Did this happen before your changes?
To 99 FRC battery drain
