Accessory 12 volt source
Old Sep 14, 2021 | 06:17 PM
VETTEYOG's Avatar
VETTEYOG
2024 C5of the Year Finalist - Unmodified
Default Accessory 12 volt source
Hi C5 gang, I wanted to rewire my 12 volt power port (the one in the storage compartment between the seats) to be off when the ignition is off. Where is the most convenient location to get a 12 volt accessory wire. I know about the set of wires in the floor by the BCM, but was looking for something under the HVAC controls or radio.
Thank you.
Old Sep 15, 2021 | 02:52 PM
wydopnthrtl's Avatar
wydopnthrtl
You could use the front 12V plugs power wire to trip a relay.
Old Sep 15, 2021 | 07:19 PM
VETTEYOG's Avatar
VETTEYOG
Thanks, but it is on when the key is off. I want it to be off when the key is off.
Old Sep 16, 2021 | 04:21 AM
oelarse's Avatar
oelarse
Above the Body Control Module in passenger footwell you these three wire ends taped like the photo shows .
Black i ground , Orange is allways ON and Yellow is from your ignition key .
Old Sep 17, 2021 | 08:05 AM
Simtech's Avatar
Simtech
Ok, Bear with me I am not all that good at explaining things.
First Get one these add a fuse things from walmart or autozone.
Next pull fuses 1, 7 and 11. These are for the CLSL CIG (the one you want) the C/LTR ( if you want it switched) and where you are getting the switched power ASRYOFF.
Plug the add a fuse into 11 and add 2 short wires to the add a fuse to plug it into the non hot side of the Cig lighter(7) and the accessory cig lighter(1 ).
Done.
My car has been like this for years now and i have had no problems with it.
I found this on the internet years ago but could not find it again so here it is. Hope this helps.
Also I like this way because it doesn't involve cutting any wires.
Old Sep 17, 2021 | 10:43 AM
helga203's Avatar
helga203
Thank you.
Is this so u dont have to keep unplugging a device.
Old Sep 17, 2021 | 10:50 AM
Simtech's Avatar
Simtech
That's why I did it, and I will never use my cigarette lighter so I did it also.
Old Sep 17, 2021 | 10:52 AM
helga203's Avatar
helga203
Me to, don't know how many time i forgot to unplug. dead battery the next day.
Old Sep 17, 2021 | 11:50 AM
Speedy007's Avatar
Speedy007
Use a fuse tap listed and pictures above look in your fuse box for the correct acc
Old Sep 18, 2021 | 08:40 PM
ThomasR's Avatar
ThomasR
Pull fuse 1 and run a fuse tap from B of fuse 11 to A of where fuse 1 was and install fuse 1 in the new fuse tap?
It's not the most professional install IMO, but it should be easy to do, all contained in the fuse box. There's a high and low beam wiring kit like this I'm not crazy about either but people use it with success.
Old Aug 29, 2024 | 04:51 PM
jpb1978's Avatar
jpb1978
I have spent hours digging around under there and cannot find that pigtail in my 2004 Z06. Very frustrating.
Old Oct 20, 2025 | 02:22 PM
fun_n_sun's Avatar
fun_n_sun
Default This works!
[QUOTE=Simtech;1604037694]Ok, Bear with me I am not all that good at explaining things.
Thanks your idea worked for me. I change both ports to I wish there was a way to include these in the 10 minute accessory delay but this fuse is instant off when you turn off the key. Still a good solution. If anyone knows how to keep the circuit running for the extended accessory mode I’d appreciate you sharing.
thanks ,
T
Done.
Also I like this way because it doesn't involve cutting any wires.[/
thanks,
To Accessory 12 volt source
