White exhaust smoke, overheating
Old Sep 14, 2021 | 07:24 PM
CapslockAnt's Avatar
CapslockAnt
Default White exhaust smoke, overheating
I'm troubleshooting some issues on my 02 C5Z where I'm getting a bunch of white smoke under hard acceleration, and some overheating. The strange part is that I just recently within the past 5k miles replaced the head gaskets, and I don't have any milky oil -- it's clean.
Suggestions?
Old Sep 14, 2021 | 08:54 PM
MikeTN77's Avatar
MikeTN77
I'm sure someone with more knowledge than I will chime in soon, but it sounds to me that what you are seeing is not smoke, but steam. Is it coming out of both pipes? Your recent head work may be a clue. It sounds like you are burning coolant, maybe your gaskets aren't seated good, head bolts not torqued to spec..possible cracked head..etc. In the meantime a leakdown test might help narrow it down. Maybe try posting in C5 tech...good luck and keep us posted
Old Sep 14, 2021 | 09:42 PM
KOZ's Avatar
KOZ
Head gaskets
Old Sep 14, 2021 | 09:47 PM
DDaaryl's Avatar
DDaaryl
White smoke is an indication of coolant in the combustion chamber. Head gasket or bad head.
Old Sep 14, 2021 | 10:07 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Ok, here's a shot in the dark. I once pulled some heads off an Olds and a lot of coolant got dumped into the exhaust manifolds. I fired it up after the job was done only to see steam coming out the tailpipes.
I called a good friend who told me to drive it up a hill to empty the exhaust. He had done the same thing as I had and had changed his head gaskets 3 times trying to hunt down the problem. Who knows?
Old Sep 16, 2021 | 11:32 AM
CapslockAnt
I’m almost certain it’s the head gaskets also, I’m just not sure how they could’ve gone bad already and it scares me that it could just happen again. I had the heads resurfaced before putting them back on.
I forgot to mention that when I drive the car hard, coolant comes out of the overflow spout — so there is definitely air leaking in somehow. The temps have been spiking up to ~235 on an all aluminum radiator with hard freeway driving.
I have ARP head studs so taking the heads off won’t be too much of a challenge.i have the intake manifold off and I’ll be draining the coolant and pulling them this evening.
Old Sep 16, 2021 | 02:00 PM
Moved to C5 Tech.
Old Sep 16, 2021 | 02:24 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
OP, looks like your replacing one or both head gaskets again. Everything you have said points to the gaskets (assuming no issue with the heads or block). One poster asked if the white smoke is coming from one or both tailpipes. If you have a true dual exhaust with no crossover pipe of any kind, this would be a useful clue as to which gasket failed. But if you do have a crossover pipe, I am not sure this is helpful. Anyway, food for thought.
Best of luck!
Old Sep 16, 2021 | 02:30 PM
CapslockAnt
Best of luck!
The smoke comes out of the entire exhaust, and is much more prevalent under WOT / high RPM (ie: huge clouds). Would a cracked head or block be leaking coolant? I don't see any coolant near the heads or around the block, although under the radiator there appears to be a bit of fresh coolant -- I'm assuming this is from the air pressure in the cooling system forcing coolant out via radiator/reservoir.
Once I have the heads off, are there any visual representations of a blown head gasket that will help me confirm?
Old Sep 16, 2021 | 03:24 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Get an IR thermometer and take temps of each of the exhaust ports as they come out of the engine. You MIGHT be able to find a cooler one that would indicate where the problem is, or at least narrow it down. Best of luck to you, sounds like you've got a job ahead of you on this one.
Old Sep 16, 2021 | 07:45 PM
PerryKing's Avatar
PerryKing
2020 C6 of the Year Finalist - Modified
If its pushing coolant then it’s a gasket or a cracked head.
Old Sep 16, 2021 | 09:45 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Could be a cracked cylinder too, but I do agree that the gasket and head (in that order) are more likely.
OP - it makes sense that the white smoke is most prevalent at WOT, that's when cylinder pressure is highest.
Old Sep 16, 2021 | 10:29 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
If you start the engine with the coolant reservoir cap off and you let the engine warm up you may be able to see bubbles in the reservoir as you race the engine. If you do, you know the head gasket is blown. Some times the pressure in the cooling system will just push coolant into the cylinder or exhaust.
Old Sep 17, 2021 | 08:58 AM
grinder11's Avatar
grinder11
To the OP: Why were the new head gaskets installed in the first place. Performance work, valve job, or??? If you had this problem before the new gaskets were installed, I'd say bad head(s), but it's unlikely BOTH heads are bad, or a cracked cylinder/block. A bad head gasket can do what you're describing, with no coolant in the oil, or vice versa. With ARP studs, did you use the ARP assembly lube? It's a very important part of the install, otherwise you'll show the heads at the proper torque value, when in reality, they might be 10/20/30ft/lbs too low!!! Best of luck, and hope this helps...
Old Sep 17, 2021 | 09:02 AM
grinder11's Avatar
grinder11
Visual representations? YES!! The bad cylinder(s) pistons and combustion chambers will be squeaky clean, with no carbon at all. Why? Because they're being steam cleaned every time the 'bad' cylinder is starting the intake stroke, and fires!!
Old Sep 17, 2021 | 10:29 AM
helga203's Avatar
helga203
Do a psi test and when did u change head gaskets?? Like up above said antifreeze gets into exhaust and takes a little bet to evaporate. Did this many times. i changed heads i freaked out. He needed the car that day. Drove it for half the day and all was good. Like i said dont know when u changed gaskets.
Old Sep 17, 2021 | 11:52 AM
Speedy007's Avatar
Speedy007
Head gaskets are most likely spent .. but now u should take off the heads and them leak tested at a shop ….prob cost ya 75-80 bucks …
To White exhaust smoke, overheating
