C5 Chassis flex
Old Dec 21, 2002 | 11:47 AM
shaky's Avatar
shaky
Default C5 Chassis flex
I was reading the Pop Sci article "King Cobra Talks Hybrids" the other day. In this article they were comparing the flex in the 1962 cobra chassis, 700 lbs per degree of flex, to Carroll Shelby's latest creation, an aluminum honeycomb chassis with a rating of 12 000 lbs per degree of flex. In the GM vette promos they talk about how they have stiffened up the C5 chassis. Does anyone know the flex rating on our chassis? You never know when this bit of trivia will come in handy. :)
Old Dec 21, 2002 | 01:44 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: C5 Chassis flex (shaky)
:lurk:
Old Dec 21, 2002 | 04:54 PM
2KFRC5's Avatar
2KFRC5
STIFFNESS (Hz = resonant freq.)
C5 convertible = 21 Hz (61.5% stiffer than C4 Conv.)
C5 Hardtop = 23.5 Hz (12% stiffer than C5 Conv)
C5 Hardtop = 80# lighter than C5 Conv.)
I don't remember where I got this info, nor do I know how this converts to lbs per degree of flex.
Hopefully someone with the expertise will chime in on this.
Me too. :lurk:
Old Dec 21, 2002 | 10:18 PM
silver386's Avatar
silver386
Cruising
I would like to see some numbers on that too.
Old Dec 21, 2002 | 11:59 PM
rwj383's Avatar
rwj383
Default Re: C5 Chassis flex (silver386)
all i know is that my coupe is STIFF!! It blows my mind. I inadvertently came across this little test: I had my car up on 4 jackstands a little while back dealing with some exhaust issues. I had 2 stands under the rearend girdle and one on each side of the front end of the car on the jacking point just forward of the doors (behind front tires). I took the front passenger side jack out from under the car so that the car was resting on just 3 jackstands. to my amazement, the front pass tire was still the same distance off the floor and the front driver tire!! the pass door opened and closed like butter. there was NO contortion or body twist i could see. this is one stiff car. all the other cars i've ever owned, including my 91 ZR1, would have flexed severely under these same conditions. I remember being able to hear twisting, creeking and flexing of body panels, doors and hatches when jacking these other cars up. no my C5.
[Modified by rwj383, 11:01 PM 12/21/2002]
Old Dec 22, 2002 | 03:05 PM
shaky's Avatar
shaky
Default Re: C5 Chassis flex (rwj383)
I did a bit of searching around and GM doesn't appear to be publishing this type of info. No surprise I guess this type of data would be confidential. What I did find was the techniques used to manufacture the C5 chassis have resulted in 450% improvement in rigidity. The article didn't say what the improvement was compared to though.
Old Dec 22, 2002 | 03:12 PM
SFVetteman's Avatar
SFVetteman
From what I've read they designed the C5 as a convertable first to be sure it didn't have the shakes and rattles of previous convertables. That automatically made the coupe stronger and the hardtop the strongest (no removable roof panel).
Old Dec 22, 2002 | 03:14 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Want a realtime lesson in chasis stiffness? I had a flat tire on the front right hand side. When I pulled over to the curb I got out to see the tirea had come off the bead of the rim and the rim was suspended in the air. :eek:
vetterdstr :cheers:
Old Dec 23, 2002 | 01:43 PM
korvettekarl's Avatar
korvettekarl
Default Re: C5 Chassis flex (vetterdstr)
Ford put those numbers in to dazzle people. You can make some people believe anything you want if you throw enough-mean nothing numbers- at them. Just my opinion. Ford has always had a slight inferiority complex when it comes to the Vette and thier pony car.
Old Dec 23, 2002 | 03:12 PM
Duck916's Avatar
Duck916
You must not have much suspension travel....
Old Dec 23, 2002 | 03:13 PM
Duck916's Avatar
Duck916
Default Re: C5 Chassis flex (korvettekarl)
I may be wrong, but I assumed this was referring to the Shelby Series I, which is not a Ford product. It actually has an Oldsmobile motor.
Old Dec 23, 2002 | 03:36 PM
rrobert22's Avatar
rrobert22
:skep:
Old Dec 23, 2002 | 03:45 PM
vetterdstr's Avatar
vetterdstr
Default Re: C5 Chassis flex (Duck916)
You all have the same travel that I do.
vetterdstr :cheers:
Old Dec 23, 2002 | 06:47 PM
C5 Frederik's Avatar
C5 Frederik
Next time we get a vette we will measure it. The way we do it is called one wheel drop test.
Last time DC had a vette it was mainly for examinating the HUD. Car was gone two weeks later.
The numbers up above in one answer are those for dynamic stiffness. Global static stiffness has to be measured separately and cannot be equated out of that ones.
Frederik
Old Dec 23, 2002 | 06:53 PM
msuc5vette's Avatar
msuc5vette
Default Re: C5 Chassis flex (C5 Frederik)
I jacked my car up from one side to put a jack stand under, then went to jack the other side up to make it level and noticed that the other rear wheel was off the ground only slightly less than the one which was held by the jack.
I attribute this 100% to downard travel of the front end on the suspension of the oposite side, I am sure that if I had the front jacked the back would have been at the exact same height on both sides.
[Modified by msuc5vette, 11:55 PM 12/23/2002]
Old Sep 16, 2018 | 01:58 PM
Corvette 22's Avatar
Corvette 22
Default How to measure C5 chassis flex
I have an ‘03 Z06 with an 8 point cage. I had been driving it as a 6 point cage for a while (without the 2 forward bars from the A pillar through the firewall to the front of the frame). I noticed when angle parked at a weird curb where the left front wheel was about 4” higher, putting a twist in the frame, I had much difficulty getting my swing-out door bar pin to release. The front of the frame had twisted! Later as I was fabbing the forward bars, I discovered that (with the car just sitting there on the garage floor) turning the wheels full lock to the right, then left, caused some frame twist. Using a 48” carpenter level placed under the front and rear suspension crossmembers, I measured 1/8” gap (@ 48”) difference from wheels left vs right. This is probably due to minor castor change. This is NOT just measuring at the front crossmember, but is measuring the DIFFERENCE between front and rear crossmember levels, ie the TWIST change of the frame.
After welding in the forward bars, I measures NO twist, even at that weird parking spot, no problem getting the pin out. I know the C5 is stiffer than previous Vettes and the frame looks massive, but they do move,,,,,just more than I imagined.
To C5 Chassis flex
