What injectors are these
Old Sep 18, 2021 | 12:48 PM
CMC76's Avatar
CMC76
Default What injectors are these
So another day wasted by the used parts....
left is what was in car. No idea if they are stock.
the whiter ones are supposed to be 42lb direct swap.
Naturally I'm putting the car on a dyno Monday.
So I'm Not likely going to have the fuel I want.
not only are the supposedly 42lb injectors a different plug. Which I can assume is normal.
they are almost an inch longer
So part curiosity.
Part venting as I've had some rotten luck on the parts board on here
Old Sep 18, 2021 | 12:59 PM
CMC76's Avatar
CMC76
So a quick 5 minutes search
maybe I just didn't do my homework.
Appears harnesses and pull off the stock height adapter may fit
Why would stock injectors have height adapter though?
Old Sep 18, 2021 | 08:10 PM
jamieo's Avatar
jamieo
Those on the left look like LS3/LS7 injectors.Any part number on them?The connector looks like the multech style instead of the ev6.
Old Sep 19, 2021 | 10:44 AM
CMC76's Avatar
CMC76
I'll take another look.
they were delphi. But I had to put them back in.
They definitely aren't the stistock ones now that I've been looking
To What injectors are these
