Tcs28 active handling
So I checked battery voltages and my battery was only reading between 12.1 and 12.5 after sitting overnight or for two or three days. I drove the car and the battery voltage on the DIC never got above 13.3. I performed a load test on the battery and it dropped to 11.8 and recovered to 12.2. I figured that it was possible the battery was failing (NAPA Premium AGM) after only 3 years. So I purchased a new Odyssey Extreme AGM and it seemed to work fine for about 10 days. I drove the car the first day and it was showing 14.3 volts on the DIC and then a couple of days later it was showing 13.8 but still no codes that is until today. The car hasn't been driven much other than to the store and back five or six times which is about 5 miles round trip and possibly two or three 20 mile trips and today the Active Handling / Service ABS System TCS28 code reappeared when I first started the engine. I checked the battery when I got home and the battery was only at 13.3. I back probed the alternator to see if it was putting out enough and according to the meter it was putting out 12.9 and surged only to 13.6. No matter how high I revved the engine I couldn't get the alternator to go past 13.6 and the battery higher than 13.4.
I am now wondering if it is possible I may have an intermittent short in the alternator or possibly a failing diode or regulator which is not allowing to the battery to fully charge and stay charged. As I said the codes clear themselves after the car has run for at least twenty or so minutes which in reality is enough to bring the battery back to a reasonable voltage rate. So if it isn't the alternator or the grounds that I have cleaned as well I'm sort of lost. I know it could be many things but I can't help but think it is something very simple. Can someone please shed some light on this problem for me?
With some soldeering skills it is usually an easy job to replace this relay feeding the ABS solonoids
How to is shown in this
