Correcting off-center steering wheel after 4-wheel alignment
I would take it back to them and have them correct it ....you may make something else worse...just sayin
From what I've seen on YouTube videos on the same subject, but on different cars, you just need to ensure that both inner tie rods are turned equally in the same direction using incremental adjustments. I'm just looking to confirm if it's basically the same process for the C5 and that no other adjustments are required. Making another appointment would mean I'd have to take some time off from work so I can bring the car in and wait. Saturdays are the worst time to bring a car into the local dealership for service, even with an appointment.
Here's a pic for him.....
...except this one is straight...
It is not a high skill deal, so no more concern when again returning to the low quality place than going there the first time.
Returning there might get you some make up cash or services, if you still will trade with the place, and, more importantly , will make management aware of the work quality you were stuck with. maybe you will get a refund . Shoddy work can be dangerous , and an off centered steering wheel might indicate carelessness on more serious stuff. It all depends on the workman and the conditions set for him to get paid. You might want to check if the place pays enough to hire people who won't let shoddy work out the door, or if they pay crap for crap workers and hope it works out.
In my car, the alignment was done with the usual load in the car, which obviously included me behind the wheel. He used his impressive looking big track calipers, I think to show off a bit, they were nice tools, his shop also had all the computerized gear and associated racks, from an assortment of manufacturers. When the alignment was being set, I was asked to center the wheel before the steering was tightened down.
Fool proof, and alignments should always be done with the expected normal load, if one wants the best outcome. Fortunately for me, I had a center dot from when my car was an autocrosser, so I avoided a lot of otherwise embarrassing indecision in the middle of the job. This attention to detail did require me, and my usual load, to sit in the car the entire time the car was being aligned.
When I was at an alignment seminar, a newspaper delivery truck was used as an example. Driver complained of excessive tire wear, and had crazy tread wear. Had it aligned and noticed the same wear pattern developing on his new tires. Big mystery was solved when it was developed the truck was used to throw advertising papers in the early morning , a load that severely changed the aspects of the front end when loaded, messing up the projected correct alignment, which turned out to be very wrong when the truck was loaded and in use. An extreme example used to illustrate a point, but the point is , the alignment should incorporate the usual load . Had the poster been sitting in the car , the steering wheel would have been centered after being disconnected.
When I was thrashing around my town looking for suitable corvette repair, I saw a big GM SUV getting an alignment , not on a level alignment rack, but in a lumpy and steep driveway in front of the crowded shop. The guy running the alignment just kept frowning and hitting the swinging mirrors until he got a green light, then he quickly pressed a button and broke out in a smile, having just completed a computerized alignment with a full paper print out , who could argue with that kind of computerized alignment proof for the money asked .
By the way, I became AES alignment expert qualified , I forget the exact initials, but it was the usual organization one sees in certificates stuck on the wall of your local garage, or sometimes on a sleeve patch. I was at a trade show and attended the alignment talk , saw a short film and became qualified for expert certification, all in about 40 minutes. Sure surprised me.
