MGW Shifter Install
Old Sep 20, 2021 | 09:59 AM
RPGR90s's Avatar
RPGR90s
Default MGW Shifter Install
I just completed upgrading to a MGW (2000 Convertible). I also did the Anti Venom mod, although I started to remove the reverse light switch plug (same side of tranny) until I realized it wasn't the correct one.
I added two shims (about .011" thickness) to the correct plug.
I went back to the stock C5 leather ****, in place of the white Hurst cue ball I had been using on the stock shifter, as I wanted the stock look again.
I like the change. I can now see the temp readings on the HVAC in 5th gear and the throws are nice, tight. It's a very, very well made unit and the instruction videos off their website are clear and concise.
I do not see much of a difference since I added the shims to the tranny though. Is the Anti Venom mod supposed to reduce the tension back and forth, (say 1st to 2nd, 3rd to 4th), or when shifting 2nd to 3rd, 4th to 5th?
Thanks,
RPGR90s
Old Sep 20, 2021 | 10:26 AM
helga203's Avatar
helga203
Thanks,
RPGR90s
Shifting from gear to gear.
Old Sep 20, 2021 | 02:28 PM
oharal's Avatar
oharal
The antivenom mod reduces the tension on the ball detent that holds the shifter in each position. It does NOT reduce the force you feel of the synchronizer pushing back on you until the gear mates with the hub. If you don't know what you're feeling for, you won't be able to tell the difference. I always joke with my friends "T" in T56 stands for Tractor because T56's are chunky clunky tractor transmissions. They are definitely not for grandpa and grandma (hence why so many C5 have a 4L60E) and won't blow anyone away in the refinement dept.
Old Sep 20, 2021 | 03:48 PM
RPGR90s's Avatar
RPGR90s
Thank You, that's the information I was looking for.
Old Sep 20, 2021 | 05:04 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I disagree with that. Just did the anti-venom mod and it significantly changed the whole characteristic of the shifting. I used 2 washers and the feel is so much lighter. You can still feel the gears synchronizing, but shift quality was dramatically improved. I have what I think is a B&M ripper shifter and not the stock shifter.
Old Sep 21, 2021 | 10:58 AM
helga203's Avatar
helga203
If u do a search, this is a hit or miss. Did nothing for me
Old Sep 22, 2021 | 09:33 AM
VetteMed's Avatar
VetteMed
The mod reduces the degree of engagement of the detent ball into the shift mechanism in the transmission. If that's the reason for perceived hard shifting, it will help. If hard shifting is occurring for some other reason (such as incomplete clutch release, incorrect fluid choice, synchronizer problems, for example), then it will be of no benefit.
Old Sep 22, 2021 | 11:48 AM
RPGR90s's Avatar
RPGR90s
Thank You all,
I did change to Amsoil ATF fluid prior to the MGW install. I've had a few days now to get used to it and I really like it.
Old Sep 22, 2021 | 12:03 PM
helga203's Avatar
helga203
Thank You all,
THats what ive heard, many times because it's a completely different feel. Did u use anti venom??????
Old Sep 22, 2021 | 08:40 PM
C5MSG2004Vert
Funny that it would do nothing. My shifter was even harder to shift before I greased it. It was very stiff. After the grease job it was alot better so I didn't do the anti-venom mod. The other day while changing my oil I decided to do it. It was so much easier to shift that at first I thought something was wrong. Maybe you should try greasing it. Mine had very little.
To MGW Shifter Install
