Michelin Pilot PS2 tire pressure
Old Sep 20, 2021 | 10:58 AM
bakeoh's Avatar
bakeoh
Default Michelin Pilot PS2 tire pressure
Just installed a set of PS2 tires on my 2001 Z06. Tire center recommended 35 lbs psi. Seems a bit harsh riding to me. What would you recommend for cold PSI
Old Sep 20, 2021 | 11:30 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'd say something more like 30 PSI, and maybe even 29 PSI in the rears......
Old Sep 20, 2021 | 11:43 AM
Gary In NM's Avatar
Gary In NM
The tire sticker on the door frame says 30 PSI. I have the same tires and that what I run.
Old Sep 21, 2021 | 05:46 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
If you go by the "generic" tire sticker on the door, your tires can go up to 36 psi in the summertime...which is too much if you want even wear and a good footprint which will also allow the best gas mileage...other factors also play a role such as road surface material...asphalt roads are the hottest...i have a lot of them in my area so my tires heat up even more in the summer...
The "sweet spot " is 30-31 hot...I put 26 to 27 psi to reach the sweet spot and adjust seasonally....
I have been doing this for 15 years now with great success
.02 registered.
Old Sep 21, 2021 | 11:02 PM
bakeoh's Avatar
bakeoh
Thanks for the input. Going to try 30 cold for starters. See how it feels and wears. Oregon is starting to cool down.
Old Sep 22, 2021 | 11:18 PM
gimp's Avatar
gimp
Like every other car, go by the recommendation of the manufacturer of the car. 30 PSI cold. 30 PSI cold in the summer, 30 PSI cold in the winter, 30 PSI cold in the wet, 30 PSI cold in the snow. The only time you want to deviate significantly is if you're at an autocross, drag, or track event.
Old Sep 23, 2021 | 08:26 PM
johnson-rod's Avatar
johnson-rod
I had two sets of these tires. They are great! 30-30 seemed to be best - just like it says on the sticker.
Old Sep 26, 2021 | 11:52 AM
bakeoh's Avatar
bakeoh
Update.
Just got back from a long road trip. Tires were 30psi cold. Stopped at a rest stop after 200 mile run and check them. Outside air temp was 89. Tires were 34 to 35 psi.
Car handled well and pretty good ride.
Thoughts?
Old Sep 26, 2021 | 12:03 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by bakeoh
Update.
Thoughts?
That sound about right. Since the ambient air temp, when you checked them hot, was 89*, was it significantly cooler when you checked them the first time? What I'm getting at, is that "hot" pressures generally are 3PSI greater than "cold" pressures, but ambient temps will affect this. You're 4-5PSI over your initial setting, but that sounds "in the ballpark" to me.
Old Sep 27, 2021 | 02:02 PM
bakeoh's Avatar
bakeoh
Thanks for all the input. Going to stick with 30 psi cold and watch the tire wear.
Old Sep 27, 2021 | 04:42 PM
grinder11's Avatar
grinder11
You should be fine@30lbs. I ran 315/30/18 PS2s on the rear of my C5 for years at 30lbs. Only dropped the psi for the strip, which didn't make much difference. 35 cold and you'll ride like a truck,, lol......
Old Sep 27, 2021 | 08:01 PM
gimp's Avatar
gimp
Update.
Thoughts?
Normal and expected to see hot pressure about 5 PSI over cold pressure, on a reasonable day and when driving like you're "commuting". You'd see a bit higher if you were canyon carving or whatever. That seems totally good for the street.
You hear tons of people talk about tire PSI at the track or autocross or whatever, and you see so many numbers you start to wonder, right? I can tell you a story: I was at the track a few weeks ago and once my tires hit 35 hot it felt like crap, because I forgot to adjust pressures for one session, but when I lowered it to 31 it was much better, which people with BFG Rival S tires say sounds right. But that story has no real relevance to street driving. The simple truth is really simple: the manufacturer of your car tells you to put it to 30 PSI cold, when the car has been sitting and ideally not in direct sunlight - adjust it when the weather gets significantly hotter or colder than before - and you will be fine. And you are!
Old Sep 27, 2021 | 08:04 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
31 HOT is the sweet spot for best footprint for handling , even wear, and gas mileage...
Old Sep 27, 2021 | 09:53 PM
bakeoh's Avatar
bakeoh
Just want to make sure you know these are not run flats.
30 psi cold seems ok. I will try 28psi cold for a bit too.
Old Sep 28, 2021 | 02:57 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thats a good thing...as long as you get to the "sweet spot hot 31 lbs"..... that WAS for non run flats...
Old Sep 30, 2021 | 11:36 PM
lionelhutz's Avatar
lionelhutz
I run about 27-28psi cold in my rear 305/30R19 tires. Done that with a set of Michelin and a set of Bridgestone. Both pairs wore completely evenly across the tread surface. The PO was running 32psi cold and those tires had the centers worn to the wear bars with quite a bit of tread still on the edges. The front 275/30R19 I run about 30psi cold and that is working good too. With the PO's 32psi the alignment was also bad and wearing the inside edges, but the wear was inside edge worn and center worn so the 32psi was too high a pressure on the front too. The weather here usually isn't too hot relatively speaking and the tires would rarely gain more than 3-4psi when driving it. 31psi hot is working good for a 305 tire and around 33 hot seems to work for the 275 tire.
Old Oct 4, 2021 | 07:39 PM
dainon's Avatar
dainon
So is Utah. When it gets cold out, I have a hard time KEEPING 30 in the tires. The last couple of weeks, both times I took it out the TPS monitor beeped and said I had 25. But I try to keep 30 cold PSI on my Pilot ZPs year round. Seems to give me decent treadwear and good grip.
Old Oct 4, 2021 | 09:07 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I ran PS2's until they discontinued the 335-18. Great, but expensive street tire, why not Super Sport, cheaper and better? I wish Michelin offered a 335 in 18". Always ran 32 front, 30 rear. Adjusted nitrogen,lol, at track events, tires get hot, pressure rises. My rear tire was a perfect slick when retired, so I believe those pressures worked out. Good luck and enjoy.
To Michelin Pilot PS2 tire pressure
