From: [QUOTE=onedef92]Remember when that spookable closed the door on that mofo and trapped him inside tha
St. Jude Donor '06 thru '11
Ok what's wrong with this picture?
Well at the light to take a left and the blinker inside was blinking like 100mph. I knew a bulb probably blew but thought it might have been one of the Euro lights on the arsse.
Are these a pain to change out at all? Looks quite sealed in that area. Was kinda wishing it were a Euro for an easy fix. :rolleyes: Any input would be helpfull.
Thanks.
WOEII
I am not sure, but I think you can raise the headlight and remove the 3 screws to take off the headlight bezel. Then you can reach down to the light. If that is not the case, you can remove a panel under the car that screws in behind the (drivers side air dam in your case) and get at it that way. It is kind of a pain in the ****, but you can do it. BTW, if you go in from the bottom, it is a 7 millimeter socket. :D Also if going in through the bottom you obviously will need ramps or jack stands. I am pretty sure you can go in through the headlight bezel though. Good luck! :seeya
