C5 auto trans fluid “high temp” warning
Old Sep 24, 2021 | 11:25 AM
Bigspoker's Avatar
Bigspoker
Default C5 auto trans fluid “high temp” warning
I just finished a track day in my 04 C5 coupe with auto trans. It was 100 degrees when we started, 97 when finished. During first session got “high trans fluid temp” warning on console
temp after session was 270. I let it cool and did two more sessions. Each time I was running between 220-280 then warning came on.
1) should I change trans fluid before next track day?
2) Do I need an add on cooler and what is the best made option? thanks!
Old Sep 24, 2021 | 12:07 PM
helga203's Avatar
helga203
Was this ur first track with the car or u had many with no problems??
Old Sep 24, 2021 | 03:20 PM
Bigspoker's Avatar
Bigspoker
Third track day on same tran fluid. No problems on first two days but temp was 75 at first day 6 months ago; 90 at second track day 1 month ago. Car has 53k miles, 3500 since purchased from chevy dealer March 2020
Old Sep 24, 2021 | 03:48 PM
grinder11's Avatar
grinder11
270°F is mighty hot for an A4!! I'd change the fluid immediately. That or have it flushed. Used to be a rule of thumb that for every 20° increase in fluid temps over 200°F, 'useful' life of transmission was cut in half. You have surpassed that first 20° increase by a huge margin.......
Old Sep 24, 2021 | 09:31 PM
tabbruzz's Avatar
tabbruzz
I would get a tranny cooler and bypass the rad cooler if you plan to track it.
Old Sep 26, 2021 | 12:54 AM
jim993's Avatar
jim993
I have been running my A4 on track, now starting my 12th year and 23rd track day coming up. Six days at Buttonwillow Raceway, 13 days at Laguna Seca and 3 days so far at Arizona Motorsports Park.
Of the above tracks, the transmission runs warmest at Arizona Motorsports Park on a 95+ day, next Laguna Seca on a 90+ day.
In order to keep the transmission cool I have added a DeWitts radiator with both transmission cooler and engine oil cooler, a B&M finned aluminum transmission pan with extra capacity and an auxiliary transmission cooler in front of the condenser.
The auxiliary transmission cooler is plumbed in series AFTER the DeWitts radiator cooler. In addition I run Red Line D4 full synthetic ATF for better protection against oxidation of transmission fluid when HOT.
On track I only use 2nd and 3rd, monitor the DIC for transmission temperature and decide to come off track if transmission temperature hits 250.
Old Sep 26, 2021 | 05:58 PM
grinder11's Avatar
grinder11
I will also add that a higher stall converter is going to make the trans run hotter, all other things equal. I'm not saying you have one now, just a bit of advice if you're thinking of adding one. Jim 993 has a good setup, with cooler AFTER the radiator, and a good rule of thumb parking it after 250°. I'm sure the 'old school' rule of thumb I gave you has changed for the better since the advent of synthetic fluids. But 270° is HOT no matter how you care to look at it.....
Old Sep 27, 2021 | 08:05 PM
gimp's Avatar
gimp
For the A4, I'd probably go as far as to change the fluid after every track day if you're hitting it hard. And if you're hitting it hard regularly, a dedicated cooler can definitely do better than the shoddy integrated one, which is not at all meant for track days.
To C5 auto trans fluid “high temp” warning
