Questions about torque management (A4)
Thanks,
Adam
That said, putting in higher gears 3.42 or 3.73 actually reduces the strain on the transmission as the drive train now has more of a mechanical advantage in turning the wheels. Since my 3.73 install, I can get going much faster and do not trip the TM. I would go so far as to say that with only an intake bolt on and the 3.73 gears - stock TC, you will experience a whole different car - but read some of the other posts on the subject.
Think of it like this. If TM "trips", the tranny was at a borderline condition. Turning it off does not make that condition go away, it allows it to go higher etc - worse. It only allows it to threaten the tranny. You can do shift firmness and shift speed without loosing TM.
I hope tht Predator soon makes that a selectable option.
If you come to Atlanta - let me know and I'll give you a ride.
[Modified by KingTut, 11:34 AM 12/22/2002]
I do have some question about the 3.73's vs. 3.42's KingTut. A majority of my driving is highway and I was wondering what kind of rpm's you are turning with the 3.73's at say 70 and 80 compared to the 3.42's?
Thanks,
Adam
To me this is a negligible amount and i recommend that you get the 3.73s if you can stomach the extra cash. I think the 3.73s are perfect for the A4 and of course i would match that up with a sy 3500 stall or something equivalent.
Best of luck Good luck.
MTI 427 Roadster :cheers:
I have the Predator and can tell you it is worth every dollar. The shift options alone are far more user friendly and changeable than any shift kit. As for Torque Management, it was GM's way of trying to alleviate some warranty repair $$$ for people that ABUSE the Vette. I don't ABUSE mine!!
Are you sure about the predator doing anything to torque management let alone removing it?
I downloaded and read the Predator’s user manual and could find nothing in there to the effect that it removes or changes torque management. It would seem to me that if the Predator were capable of removing torque management that would be via an adjustable parameter that would allow users to raise the torque management by degrees until it is removed altogether. No such adjustable parameter is mentioned.
Considering the cautions to users about modifying Predator parameters, I can’t believe that the program just removes torque management altogether or changes it without telling you about it. That would result in lawsuits from users as the stock C5 A4 needs torque management to survive.
By the way, traction control is different from torque management.
When you change differential gears you need to tell the PCM that you did or it will interpret the difference between input speed and output speed as transmission slip.
"Revised Torque Management Settings for optimum performance..." http://runninwiththedevil.com/predator.htm
I wonder if this means the TM change must be buried in the Predator stock performance programming portion of the tune somewhere. :cheers:
I have some of the same questions about what Predator does to TM. Eventhough it's not in the manual one of the vendor sites talks about:
I think I'll email them to clear up this point and report back the answer :cheers:
GM limits the torque output in Corvettes with A4’s to 360 while the MN6 has 375. I believe they are being overly cautious in order to avoid warranty repairs. For the bone stock A4, using the Predator probably wouldn’t present any problems but for cars that have bolt on mods then that might hurt the longevity of the transmission depending on how much torque management has been reduced IMHO.
I want better shift points, shift pressure, and necessary changes for my gears, but at what cost? I think this is a design flaw and as soon as someone with a Predator blows their transmission and it is not warrantied, the fan will turn a darker shade of brown and the change will get done.
