cruise control disengages
Old Sep 26, 2021 | 11:20 AM
Glasact's Avatar
Glasact
Default cruise control disengages
Yesterday while out for a 2 hour drive, I had my cruise turn itself off (2) two times. Once traveling at about 45-50 MPH and the other time about 65 MPH. It was as if I lightly touched my clutch or brake pedal. She's a well maintained 2003 with 39,000 miles. When I got home. I checked for any codes and found none. Anyone ever experience this?
Old Sep 26, 2021 | 11:34 AM
helga203's Avatar
helga203
Yep common problem. There are micro switches are under dash so when cruising the switch is closed when peddle is up but if that switch gets loose it will open circuit and trun off CC. Its not in the easies place so hope ur a small guy because u have to lay on ur back to see then. They are yellowish.
Old Sep 26, 2021 | 06:09 PM
Moved to C5 Tech.
Old Sep 26, 2021 | 07:34 PM
3sACROWD's Avatar
3sACROWD
While driving with cruise on, try tapping the clutch or brake pedal from the side and see if the cruise kicks off.
If you do work under the dash, remember there are only 4 nuts and an electrical connector keeping your driver's seat in the way. In less than 10 minutes you can have the seat out and have plenty of room to work.
To cruise control disengages
