Secondary air vacuum module
Old Oct 6, 2021 | 06:26 PM
Signalman Dan's Avatar
Signalman Dan
1st Gear
Default Secondary air vacuum module
Does anyone know the function of the vacuum module on the secondary air system and can it be deleted?
Old Oct 6, 2021 | 07:40 PM
Smoken1's Avatar
Smoken1
I removed all of it when I did heads and headers, you will need to tune the codes out when you do it
Old Oct 7, 2021 | 12:25 AM
jim993's Avatar
jim993
But check the local smog/ vehicle inspection regulations before disabling any part of the secondary air system.
Old Oct 7, 2021 | 06:36 AM
runner140*'s Avatar
runner140*
I removed the entire A I R system..pipes/hoses/air pump/electronics/check valves etc. Replaced with block off plates etc. There are no state inspections in Florida.
Old Oct 7, 2021 | 11:00 PM
Moved to C5 Tech.
To Secondary air vacuum module
