EBCM repair test
Old Oct 11, 2021 | 10:58 AM
ricrose's Avatar
ricrose
Default EBCM repair test
I got my EBCM out, opened and soldered. Anybody know of a way to test the unit while it’s out of the car to see if my repair was successful? Multimeter? After the hours long struggle to get the thing out, the idea of reinstalling it only to maybe take it out again, is too horrible to consider.
Old Oct 11, 2021 | 10:52 PM
joeflyer's Avatar
joeflyer
I don't know any way to test the unit before reinstalling it, but you can use two screws to start out, and if it works, add the other four. If you replace the Torx screws with hex-head screws it will be easier to reinstall and remove again, if needed. Also, some of the screws are easier to remove and install from under the car.
Old Oct 12, 2021 | 12:02 PM
ricrose's Avatar
ricrose
Good to know, thanks.
Old Nov 1, 2021 | 08:57 AM
Vetman99's Avatar
Vetman99
3rd Gear
Default EBCM -soldering
What year is your Vette? I was wonde6ring if possible to solder 1997-2000 .Or if thats just for later models.How did yours turn out,?
Old Nov 1, 2021 | 09:36 AM
666lisa's Avatar
666lisa
1997 to 2000 cant be repaired.
Old Nov 1, 2021 | 01:13 PM
ricrose's Avatar
ricrose
It was a bear to get the box out of the car but it worked out great. Sorry to see the other reply that states you can't do yours.
To EBCM repair test
