Which spark plug?
Old Oct 11, 2021 | 09:40 PM
Rockitansky775's Avatar
Rockitansky775
Default Which spark plug?
Hi all, I have a 2002 Z06 383 stroker track car that has mahle pistons, OEM ignition, crane cam, ported heads and headers on pump gas 93. I have no idea what compression ratio or size of cam unfortunately. Currently it has NGK TR5IX Iridium spark plugs, my question is is this a good plug? It runs at full throttle and no street use, but I have read a colder plug might be in order? I also heard silver tipped plugs might be a good choice? THX Brian
Old Oct 12, 2021 | 08:52 PM
oharal's Avatar
oharal
What problem are you trying to fix?
Old Oct 13, 2021 | 09:55 AM
Efx's Avatar
Efx
i have 442 stroker (12.5 compression) and i run TR6 gapped @ 0.39
Old Oct 13, 2021 | 11:00 AM
Speedy007's Avatar
Speedy007
I use a tr6 gapped at .30
Its work but I found my cam spec through a QR code and a number when I did a rear main seal that let me know it’s a stock ls1 cam spec after looking it up.. I’m sure there may be other way to figure out what it’s got maybe a tuner could give you some sorta range as well based off the tune possibly
Old Oct 13, 2021 | 02:51 PM
Pb82 Ronin's Avatar
Pb82 Ronin
I've run several plugs (OEMs, TR6s, AR-103s, etc.)...curious about other experiences and why they use what they use.
To Which spark plug?
